Home > Maintenance & Mods (L322) > Bubbling B Pillars
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
Bubbling B Pillars
Hi guys, i have 2 patches of small "bubbling" on either b pillar drivers side and passenger side.
the black b pillar trim on the edge of the window on the outside, are these replaceable, they look as though they are not part of the door
would probably be cheaper for me to salvage some rather than have them repaired/resprayed
thanks in advance, scott
Post #334748 27th Jun 2015 6:52pm
CS
I have had the door window trim replaced twice under the three year paintwork warranty. I think it clips on in some way. Only Range Rovers since 1988
Post #334912 28th Jun 2015 5:52pm
Ohwhatalad
I've attached a picture you can see the pillar plastic trim bubbling at the bottom I can't seem to find the part anywhere then?
Post #334925 28th Jun 2015 6:44pm
pld118
Part No. DDC000121PMD (COVER, RH, BLACK, '"B" PILLAR") ?
Post #334935 28th Jun 2015 7:56pm
Ohwhatalad
Amazing thank you for that. Now just to figure how it comes off haha !
Post #334942 28th Jun 2015 9:49pm
Spookily that's exactly where mine is bubbling Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #334949 28th Jun 2015 10:56pm
Ohwhatalad
Design fault then Sad 35 quid each for new ones not so bad looks like 3 or 4 screws hold them on under door cover. Gonna order mine today
Post #334981 29th Jun 2015 7:21am
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Hi Ohwhatalad,
I need to do this to mine as well, be good to know how you get on. Life is what happens while you�re making other plans.
Post #334988 29th Jun 2015 8:13am
Ohwhatalad
ordered from brit-car so will let you all know how i get on with replacing them!
Post #335004 29th Jun 2015 9:48am
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Any idea how much for the rear ones are (519C06B)
And how to remove/fit Thumbs Up
Post #335020 29th Jun 2015 11:27am
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Real interested too Accept, some days your the pigeon, some days your the statue!
Post #335175 29th Jun 2015 7:22pm
Ohwhatalad
Hi guys
All done, sorry no pics but there's no need really it's very simple.
1. Open window fully
2. Pull slowly on the weather seal, inside the door up the side of the pillar until it exposes 3 screws, undo them
3. Pull the pillar cover upwards (it goes into the door about 4 inches
4. Pull it backwards away from the door until it u clips
Refit new one screw in and push weather seal back into place. Some lubricant may make things easier although I didn't use any.
You will find a build up of stale water and dry white salts under where is has bubbled. Seems to be where the weather seal has been compromised maybe by jet wash etc. seeing a as my car is 2005 ten years of build caused minimal bubbling but annoyed me enough to swap.
The pillars cost 36 quid each from Brit-part. Need any more info just ask
Post #335617 2nd Jul 2015 8:50pm
Knightmare
Hi Ohwhatalad,
Thanks for that, really useful. I'll order mine today. Very Happy Life is what happens while you�re making other plans.
Post #335667 3rd Jul 2015 7:32am
Knightmare
Hi guys,
Did mine today and took a few pics in case it helps anyone else.
The trickiest part was getting the weather strip back into position. As Ohwhatalad said, some lubricant/soapy water may help Rolling Eyes
Post #336648 9th Jul 2015 2:11pm
Ohwhatalad
Nice one Thumbs Up
Post #336649 9th Jul 2015 2:12pm
