Home > Technical (L322) > Front Side Lights (Menu help required)
BigPete
United Kingdom 2011 Range Rover Autobiography TDV8 Fuji White
Morning All
Can these front LED side lights be set as DRL's???
Also, when i select auto lights on the switch, they come on, inc the rears, even in 100 degress of full sunshine... Shocked Any thoughts???
Cheers Guys an Gals.
 2011 TDV8 Autobiography
Post #334660 27th Jun 2015 11:10am
iKushtyy
England 2007 Range Rover Vogue TDV8 Stornoway Grey
I thought they were DRL's on a 2010+ MY.. I have thought about the same thing, as I have an '07 facelifted.. Somewhere in the menu, see if there's anything in the 753 hack menu??.. (I don't know what's in the 2010+ menus)
On a sidetrack, my friends Merc E class has DRL's, but they only run when he turns lights on, or has it on Auto.. If he actively turns the light off, the DRL goes out too.. Also, he has an option to turn them out in the settings, that's why I suggest 753.
Oh, forgot to add, the 753 can also tell you about your ambient light sensor for the auto lights setting. There should be significant voltage difference between light and darkness..
Post #334665 27th Jun 2015 11:35am
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
I put mine on using the iid, to be honest its not worth it, they are not bright enough to see.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #334724 27th Jun 2015 5:08pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Same here. But at least they are on when you are driving. Thumbs Up
Post #334780 28th Jun 2015 12:49am
Roystonh
The dealer workshop can switch them on as DLRs through the computer - had it done on my last one and they will be doing it on my new one in a few weeks time. 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #334781 28th Jun 2015 1:06am
BigPete
Never actually tried to access the hack menu, didnt even know it existed!! Embarassed
Aanyone give me a step by step on how to do it please?
Me being me, can i do any damage that is irreversible?? Whistle
Many Thanks. 2011 TDV8 Autobiography
Post #334800 28th Jun 2015 8:52am
BigPete
Also, on Autolights, surely in daylight they shouldn't come on should they?? Question
Should only come on in poor light.....one would think. 2011 TDV8 Autobiography
Post #334802 28th Jun 2015 9:11am
iKushtyy
There's plenty of videos on YouTube on how to get into the menu. I can share the '07 way, but I don't know if it'll be slightly different on the 2010+MY.
With the ignition on, put the ICE onto the TV. When the TV is on, press the home soft key in the corner to take you back to the home menu. Then put your finger right in the middle at the top of the screen and hold it there for 5-6 seconds. After this, hold the navigation hard key for 5 seconds. If done correctly, a keypad will appear on the screen. Press 753 and enter, this brings up a basic self diagnosis system and information about your car.
If there's a way to turn on the DRL's without plugging anything into the OBD, it'll be in there. Also, one of the options (can't remember which one) will give you a voltage reading for your ambient lighting sensor. The sensor is in the rear view mirror, and yes the headlights shouldn't illuminate in the daytime. Throw a towel over the windscreen to cover it, then shine some bright light on it, the voltage should change, if it doesn't, might need changing.
Oh, you can't break anything in there, so don't worry. Thumbs Up
Other codes can be put in the keypad screen, but I don't know what they are or what they might do.
Post #334841 28th Jun 2015 11:28am
