Home > In Car Electronics (L322) > Solar Trickle Charger - any advice? |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
Having been caught out a couple of times with a depleted battery when leaving my 2006 TD6 parked at the airport, I thought that the answer might be a solar trickle charger placed on the dashboard and connected to a live cigar lighter.
25th Jun 2015 7:57am |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2014 |
Some info here
25th Jun 2015 8:33am |
Given that it shouldn't be the case I would say you either have a small drain or a knackered battery. If it were me I would fix the problem, not mask it over. My car was fine at the airport for 3 weeks over Christmas and New Year, started just fine when I got back. Just my 2p. |
25th Jun 2015 8:46am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I have this theory that if you leave it at the airport with the window open, unlocked, and with the keys in the ignition it will be safer than a locked one.... I mean thieves will think it's a bait car and leave it well alone...
25th Jun 2015 11:00am |
If you're replacing the battery every 2 years then perhaps look at AGM as a solution. I did this on an 07 TDV8 when it was only doing short runs and I was using the FBH. Details in this thread.
25th Jun 2015 11:01am |
Many thanks, and I have found that the socket in the boot of the 56 reg TD6 is permanently live, so problem solved. I have always used Bosch batteries up till now, but I read that AGM are good.
25th Jun 2015 12:09pm |
