Home > Technical (L322) > Air Suspension inactive
leedslad
United Kingdom 2002 Range Rover Vogue SE Td6 Alaska White
Hi Ive got a 2002 td6 l322 and message came up on dash Air Suspension inactive, There are no lights on my dash where you can alter the ride height.
Looked on this website to see what was problem thought it was compressor, fitted new compressor still not working what else could it be. Dont think there is any leaks cos car is not as low as it would be.
Post #333912 22nd Jun 2015 2:25pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
You need to get the fault cleared by a diagnostic machine.
Post #333914 22nd Jun 2015 2:31pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
What does it do when you ask it to change ride height?
Post #333918 22nd Jun 2015 2:58pm
leedslad
It Does nothing no lights at all
Post #333920 22nd Jun 2015 3:03pm
Rosco
No lights at all on the centre console ride height button? Have you done a lock to lock since new compressor fitted? Thumbs Up
Post #333924 22nd Jun 2015 3:18pm
chex
Kenya
Turn the steering wheel lock to lock.
Post #333928 22nd Jun 2015 3:22pm
As Paul said, the fault is called a "hard" fault, you can't clear it unless you have a diagnostic tool even if you have fixed the problem... most garages should be able to do it but tell them your not paying if they can't clear the fault....
Or take it to the main dealer, or buy an IID tool or similar... Pete
Post #333929 22nd Jun 2015 3:22pm
Rosco
Re: Air Suspension inactive
Pete this was the OPs sentence I was alluding too, I have had the air suspension inactive warning a few times which were incorrect and were a battery issue, Thumbs Up
Post #333931 22nd Jun 2015 3:26pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
As Paul above said, if you had air sup inactive on display before you changed the compressor, the suspension would of locked up in normal hight and to re set you will need diagnostics tool like iid to clear the fault or faults. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #333932 22nd Jun 2015 3:26pm
leedslad
yes had inactive before changing compressor
tried lock to lock doesn't work
Post #333933 22nd Jun 2015 3:31pm
Yep..... message alone and normal lights on or with the lockout led in the height switch lit and the battery procedure will do it...
No lights and it's a hard fault..... Pete
Post #333934 22nd Jun 2015 3:32pm
Or drive over here and I can do it for you.... Pete
Post #333935 22nd Jun 2015 3:34pm
leedslad
Cheers Pete when's best to come over
Post #333968 22nd Jun 2015 6:38pm
Rangeyman
Yes it happened to me when I removed my compressor,no lights at all,fortunately my mate called and sorted it for me with a plug in.Ps,i managed to sort my compressor with the piston ring kit for £20 !!!
Post #333977 22nd Jun 2015 7:09pm
I'll PM you.... Pete
Post #333978 22nd Jun 2015 7:13pm
