![]() | Home > Technical (L322) > Cluster options |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Think easy exit/entry moves the seat for when you get out & in, think mine moves when I turn engine off.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
IIRC the Easy Entry / Exit brings the seat / steering wheel into your set position depending on which key you've used once your behind the wheel. Stoping the car makes the wheel go forwards and the seat backwards to make it easier for you to alight.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i'd go with that, on the earlier ones the steering wheel moves up when you take the key out and moves back down again when you put the key in |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
ah, ok that makes sense, the 07 used to do it automatically. |
