Home > Maintenance & Mods (L322) > TD6_Billowing white smoke_help? |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Hi Matricks, TDV6? It must be an L405 then? Is it still covered by the manufacturers warranty?
19th Jun 2015 8:18pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
If it is a TDV6 405, then i would sit tight and call LR assist.
19th Jun 2015 8:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35330 |
could be a tdv6 sport, if so you're on the wrong forum.. ... - .- -.
19th Jun 2015 8:31pm |
Matricks Member Since: 19 Jun 2015 Location: Wilts Posts: 17 |
Thanks,
19th Jun 2015 8:33pm |
Not heard of an intercooler failing, after all it is an air to air cooler, running at relatively low pressure, so unlikely to hole due to corrosion.
19th Jun 2015 8:36pm |
Thanks mate,
19th Jun 2015 8:42pm |
edit to above. could be the crank breather, loads of folks have swapped them out for the BMW vortex version, its a straight swap.
19th Jun 2015 8:48pm |
Thanks again,
19th Jun 2015 9:05pm |
Not sure TBH, but I'm sure one of the knowledgable TD6 owners will be along at some point to help out. The have all gone to bed early with a cocoa........or to the pub There is nothing that can't be fixed with a hammer😜😜
19th Jun 2015 9:10pm |
Thanks,
19th Jun 2015 9:21pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi. Pete haylands wrote on a thread a while ago, stating white smoke could be a sign of vacuum leak from servo into vacuum system, hence brake fluid burning off. I'm sure that he will correct me if I'm wrong.
20th Jun 2015 6:41am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Check the radiator coolant for oil on top. I thought white exhaust meant water getting burnt. Which means head gasket or cracked head. Of these two I'd bet the first as hadn't heard of a head cracking. ______________________________
20th Jun 2015 7:05am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1764 |
Turbo gone, or crankcase breather blocked.
20th Jun 2015 7:18am |
Thanks for all the advice/ pointers - far more useful than another RR Forum I posted on.
29th Jun 2015 5:26pm |
