Home > Wheels & Tyres > Cooper Discoverer AT3 Tyres on my 2005 Vogue. Very hard ride |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1388 |
I had Goodyear MT/Rs on my 2004 (19" rather than 18" wheels) 4.4 Vogue each winter for 9 years. They were noisier, used maybe 10% more fuel than the summer Pirelli Scorpion Zeroes and had a firmer feel, with longer braking distances, especially on wet roads. The sidewalls were much harder than on the summer tyres. I have not tried the Coopers but would expect them to have harder sidewalls too, especially compared with a budget tyre. The non-standard size may be a factor too, I have not tried that. Only Range Rovers since 1988 |
17th Jun 2015 4:29pm |
Adding to the above, my current winter tyre is Goodyear Duratrac again 255/55 R 19, it has a firmer feel than the Continental summer tyres, but less firm than the MT/Rs. I would not describe any of them as "very hard" though. Only Range Rovers since 1988 |
17th Jun 2015 5:47pm |
pateire Member Since: 17 Dec 2014 Location: Tralee Posts: 13 |
Thanks for that CS. Maybe I'll just have to put up with the firmer ride. Sadly the roads around here wouldn't be the best.
18th Jun 2015 8:07am |
I've been happy with the Duratracs. They are much more of an all terrain than the MT/Rs, so better road manners and the reduction in handling, performance and economy and increase in noise are much less of an issue. On soft mud I found the back of the car could twitch a bit, but I occasionally get that with the summer Continentals on lateral ridges on the road, so I wonder whether it is a feature of the weight balance of the TDV8 as compared with the 4.4 petrol rather than just a tyre issue. Duratracs also have the advantage of being a LR homologated tyre so insurers should have less of an issue with it.
18th Jun 2015 10:52am |
Yes CS, I know that road well from Lismore to Cork. Ripples is right, but a lot of the roads are worse than that. You must have been visiting the Earl in Lismore castle yes? Thanks for the info anyway. I'd never really thought about the insurers and tyres, even though I should have done. My AT3's are wider than standard but the load rating is 110 instead of 112 (1060KG instead of 1120KG per corner)
18th Jun 2015 12:23pm |
