Home > Technical (L322) > Where does this pipe go?
Andy
I've just changed my air con pipes and I spotted two vacuum hoses hanging. One I found out connects to a black plastic cylinder mounted on the inner wing but I can't see where the second one goes to
I don't know whether I've pulled it off accidentally when replacing the hose
The other end of it is connected to the solenoid on the turbo.
Any ideas anyone? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #332884 17th Jun 2015 8:54am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Not off the Black plastic accumulator that sits to the top left against the suspension turret. I think it's to do with the vacuum for the turbo, sorrhy not in car so cant go and look.
No doubt someone will put me right. Mine was a blue one! Smile
Post #332896 17th Jun 2015 10:16am
Andy
I think I've worked it out.
There were two pipes hanging. I spotted one port on the end of the reservoir. The other is on the vacuum valve that's mounted underneath the reservoir.
I'm hoping I've got them the right way round- I've connected the pipe from the turbo to the vacuum valve and the other pipe to the reservoir. Took it for a test drive and the turbo whistle I had last week has gone.
I must've disturbed it when I did the brake pipes. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #332900 17th Jun 2015 10:42am
Andy3681
Sounds right. If you want me to check I can look at mine later unless someone has a picture handy. Mine was a blue one! Smile
Post #332904 17th Jun 2015 11:34am
Andy
If you could, I'd be grateful. I phoned the dealer and he seems to think it's right. He did confirm that with a disconnected vacuum, it would overboost and over-fuel, causing the engine knock. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #332912 17th Jun 2015 12:05pm
