Home > Technical (L322) > Transfer failsafe program
leeellen
United Kingdom 2003 Range Rover Vogue Td6 Java Black
My vogue has this trans failsafe programme up on dash and it's seems to be locked into 4th gear....it resets once you turn ignition off but does it again once you drive off....has anyone had this.it had a new gearbox before I had it but don't know when...I have replaced the battery as I was told it could be that....I have also removed the transfer shifter and bench tested it and that's all working as should.....thanks in advance for any advice
Post #332518 14th Jun 2015 8:35pm
Pepi
Loads of posts on the subject
Hi I think just about every owner of a pre 2005 auto has seen this come up!
It can end up driving you to distraction and great expense if you don't try and record exactly what happens when this happens, this will save you time and money.
A great chap to talk to would be Pete Hancock AKA Haylands. Look for his posts.
Mine turned out to be the transmission isolator switch. But there are a multitude of reasons for this fault. Some show differing characteristics & symptoms pre event and post event.
It can get very complicated if you read all the posts so don't do that untill you have tied the symptoms and lead up to the event.
Then talk to Pete "Haylands" Eddie the eagle watch out 👀
Post #333282 19th Jun 2015 8:10am
Well thanks for the vote of confidence but it's RRPhil who is the resident gearbox expert, my meager knowledge is just from reading this and other forums... Phil does the hands on stuff....
Transmission Failsafe Mode comes in to protect the gearbox when the ECU "thinks" there is a difference in speed across the box, i.e, the box is slipping... this can be caused by lots of things, mechanical, electrical, heat, oil....
You need to get it diagnosed by someone who knows the problems with the GM5 unit in yours, I would phone around and see if you have anywhere local. Pete
Post #333289 19th Jun 2015 8:51am
Pepi
Thought I would recommend you😏
Give you something to do while you are sat with your feet up being waited on hand and foot😉😄
Cheers Pete Eddie the eagle watch out 👀
Post #333423 19th Jun 2015 6:08pm
Cheet22
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Sorry folks, just posted a new topic on this very subject and how mine has seemingly disappeard....i should have replied here.
In short - car off battery for 36hrs and no more messages....unless its just coincidence
Post #333575 20th Jun 2015 12:57pm
Pepi
Great news can drive you mad
Or in my case madder👹 Eddie the eagle watch out 👀
Post #333782 21st Jun 2015 6:04pm
36hours or 36 mins.... won't make any difference, you can't turn something more than off...
From you other post I would guess yours was a parasitic drain that you removed during the 36hour unplug...
Unfortunately there are many reasons for the fault and I think yours is different from the OP Pete
Post #333822 21st Jun 2015 11:02pm
Cheet22
Fair point well made
As you say, i removed amp, radio, nav, head unit and tv units- poss one of those had a drain of some sort
Post #333839 22nd Jun 2015 6:17am
Pepi
There you go told you he was good. 😄 Rolling with laughter Eddie the eagle watch out 👀
Post #333844 22nd Jun 2015 6:58am
