Home > Maintenance & Mods (L322) > Squealing brakes advice |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8249 |
If it is the lip causing it I'd be tempted to grind a chamfer on the pads rather than try to clean the discs up, it could be glased discs, that rear one doesn't look too bad but are the front discs shiny??
19th May 2015 6:06pm |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 |
If they are glazed as they are quite shiny is it worth a quick go with some emery or a flap disc ? |
19th May 2015 6:57pm |
You can try but it's usually case hardened the surface of the disc, the only answer is machining them or new ones, machining isn't cheap anymore so new ones is usually the way to go...
19th May 2015 7:46pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
It could easily be the rusty edge,i have put a file on these before today on front or rear drives with the wheels spinning but you will struggle with the 4x4.?you could try something like a dremmel without going crazy and a good rub with emery is ok.Make sure your pads are not too tight at the ends,its surprising how many times you have to file new ones that are too tight or have to take out the spring clips and file up behind! |
19th May 2015 7:49pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
OE front discs are very reasonably priced from Ducky Dan (around £60 a side) for JLR Brembo discs... Pads have come down in price too so IMHO not worth fitting anything else |
19th May 2015 8:29pm |
Montys 4x4 Member Since: 23 Dec 2014 Location: Suffolk Posts: 70 |
Had this myself after I bought an 04 TD6 the other week, it started squealing with light brake pedal pressure from the front axle, it was doing my street cred damage by announcing my departure and arrival to the street at ungodly hours. I looked at the discs and pads and thought they looked pretty good but took the plunge and ordered up new Brit part items.
20th May 2015 10:29am |
Finally sorted this. Passenger side front was not working properly one of the Pistons was sticking , got an overhaul kit for £16 stripped the caliper changed the seals and cleaned the Pistons , also on the rear calipers the lower guide pins were sticking so removed them cleaned and regreased them , as well removed the discs and removed all the rusty bits etc from them , so after all that no more squealing . |
3rd Jun 2015 6:17pm |
Top job and a nice cheap fix.... Pete
3rd Jun 2015 7:22pm |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 186 |
My front discs had a bit of a lip on my 09MY and I thought the stopping could be better. They were also making 'graunching' noises.
9th Jun 2015 10:00pm |
If it's had discs and pads done by a garage just take it back before you mess with it. |
9th Jun 2015 10:28pm |
