![]() | Home > Off Topic > What makes autos slower than manuals ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
i think the autos change gear at lower revs than a manual which can be taken up the the red line..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
It's mostly torque convertor slip that saps power, in an auto the wheels aren't directly connected to the engine, the TC has to slip to get it moving, in a manual, once the clutch is fully engaged all the power goes to the wheels...
All that handraulic stick waggling to save a few tenths off the line. Once the torque converter has locked up the auto is quicker anyway, smoother and faster gear changes with no left leg & arm shenanigans. |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Power loss through the gearbox, auto's are better than they used to be with electronic operation, older auto's used hydraulic pressure to make the changes, thus sapping power.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Haylands has a nice answer. Also, autos are more complicated and often heavier than manuals, which will also make a difference.
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 ![]() ![]() ![]() |
As stated its the losses in the Torque converter, sometimes couples with the gearing itself. Autos tend to have less gears, so will not always have the best ratio for power, meaning slower acceleration.
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
Also generally the equivalent auto would have fewer gears so would have to go faster in each gear and drop the revs more on changes. So you have a combibation of higher general losses, fewer gears, torque converter slippage and possibly more weight.
