Home > In Car Electronics (L322) > GPS ROOF AERIAL ANTENNA
super8
2005 Range Rover Supercharged 4.2 SC V8 Java Black
A number of threads around sat nav issues so thought it worth starting a post specifically around the GPS ROOF AERIAL ANTENNA which is key to all things GPS and TMC
First question... does anyone know where to get a replacement assembly... not the whole thing just the external plastic casing as over the years the plastic becomes brittle around the fin which leads to water ingress causing the GPS unit to become damaged and also can corode the solder points on the TMC unit which leads to loss of TMC signal. Range Rover - Supercharged - On the drive.
Discovery V8 - Sadly gone.
Post #186209 2nd May 2013 4:57pm
mackempete
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
If i find some where that sells the antenna. I'm happy to do a how to on replacing it. obviously once i puzzle it out for myself Smile
edited as i just realised that super8 has already done a guide in this thread:
http://www.fullfatrr.com/forum/topic17777-15.html
Post #186377 3rd May 2013 2:50pm
Johnte
Not sure if you can get the cover separate... I got the whole thing from Dan@duckworths, I think it was round £50 ish.
Post #186387 3rd May 2013 3:33pm
Kes
England 2005 Range Rover Vogue SE Td6 Java Black
GPs antenna
Hi just fitted a new gps aerial £62
Now working perfectly!!! Kes
Post #330165 31st May 2015 8:42am
Zirconblue
If it's just the cover you want, then i think Powerful do a dummy one, i expect that could be used to re-case an old one?
Post #330212 31st May 2015 11:58am
TJH1985
Hi,
Where did you get them for £50 / £62 ?
I have a Vogue SE that has developed the same issue recently.
Thanks,
Tom
Post #330297 31st May 2015 7:25pm
