Home > Maintenance & Mods (L322) > Rear Washer wont stay primed? Here's a fix for �2.75 !
rar110
I did this on the weekend. Thanks. ______________________________
Post #328842 20th May 2015 11:26pm
Dean
Scotland 2007 Range Rover Vogue TDV8 Java Black
I did mine too today. So easy I did it in my suit and tie again 👍
 2006 FFRR TDV8 Vogue
2012 Discovery 4 SDV6 GS
Post #330084 30th May 2015 7:45pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Thanks for the info Thumbs Up
Did mine, works perfect now
David 2014 vogue se
Post #330184 31st May 2015 11:06am
HGv driver
Wales
well if all the repairs i have to do to the FF are this easy and quick i'll be a happy chappy,thanks for the tip
Post #330301 31st May 2015 8:34pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Do the front washers also have this valve? Im having problem
Im having prime problems with both front and read 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #331139 5th Jun 2015 3:17pm
Dean
That sound serious - I can recommend a good doctor!
(Sorry, couldn't resist. I am sure someone with more knowledge will be along in a minute.) 2006 FFRR TDV8 Vogue
Post #331147 5th Jun 2015 5:21pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
looks good Thumbs Up NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #331151 5th Jun 2015 6:00pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Did it in 5 minutes with no tools.
Trim is held in firmly, but does pop out if careful. Just pull it down at about 90 degrees angle as pins slot straight like door trim panels.
You then find the rubber hose with a small black (square boxed) valve. Un pop both ends (pliers would help, but I twisted it out with my fingers) and then replace with the new valve. Make sure you put it in the right way. It is easy to check by blowing through it.
Now my rear wash jet is as it should be.
Awesome and very cheap fix! Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #332885 17th Jun 2015 10:01am
