![]() | Home > Technical (L322) > RR vs X5 - same engines, different maps? |
Getting an engine to be mountable transversely and got a certain gearbox wasn't really much input considering that's the same unit they use in jags and in much greater numbers.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Fuel line position, manifold shape, exhaust routing, wiring locations, engine mounting positions and the castings on the block to take them, which side does the starter motor go, even the overall profile of the engine..... There's quite a lot goes into mounting an engine in a different orientation. They would have had to have input in to all of that, pretty much the entire engine. It would have had to have been developed to suit both companies needs, unlike the V8 which was only going to be used by Ford/PAG and mounted longitudinally. |
Its not mounted differently in the psa usage though...
cl0ud Member Since: 10 May 2015 Location: United Kingdom Posts: 10 ![]() ![]() |
did you check the engine codes to see if they match? |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
It says both of them run the M62 TUB44 (VANOS equipeed version) engine.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
The BMW rr engine does not have the dodgy butterfly valves in the inlet tract that the BMW diesels do. I also understand there are extra baffles etc to help oil pickup at off road angles an rr can get to. The blocks could be the same though ? 2011 Range Rover Vogue SE 4.4 TDV8
I think the original question related to the 4.4 Petrol, but yes it shows that for the Diesels at least, its unlikely the engines were 'nobbled' for the Range Rover. |
