Home > General (L405) > Brakes Screeching At Low Speed - Anyone Have This?
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
My 13 plate SDV8 VSE brakes screech quite a lot at slow speeds when lightly applied or when coming to a stop, does anyone else have this issue?
Its very embarrassing pulling my £70k car up at lights to admiring glances only to hear it screech to a stop, not great after 3 weeks of ownership.
Hopefully it can be sorted out without the need for new pads?
Thanks
Carl
Post #329844 28th May 2015 6:52pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Nope but it happens on my Aston.
You can try an Italian anti squeal solution.
Find an empty road. Brake as hard as you can from 70mph to about 20mph. Don't stop. Repeat two or three more times.
Post #329859 28th May 2015 7:48pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Had it with my L322, kicked up a fuss with the dealer and they replaced all discs and pads under warranty. Sorted the trick for a circa 10k miles. Then they replaced them all again and it was good until I sold it!
Post #329866 28th May 2015 8:36pm
carlos50
Thanks for the replies, I think I may be getting the start of the knocking in the front suspension when going over potholes or uneven road surfaces so will call my local dealer.
I always expect to be fobbed off then end up starting to loose interest in the car, I hope this doesn't end up the same way?
Post #329869 28th May 2015 9:04pm
ebajema
Had it on the 4.2 till I did the Italian brake tune 😁 MY 2010 5.0 SC Galway green and sand interior!!
Post #329892 29th May 2015 4:05am
carlos50
Out of interest, the rear discs have visible score lines and a small lip and the fronts only the lip, how much lip is considered within wear limits please?
I've done about 750 miles in it since purchase and will be well pi**ed off if it needs new brakes?
Thanks
Post #330233 31st May 2015 1:41pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Get it back to the dealer for inspection. Both of my SDV8 models have had new anti-squeal pads fitted under warranty. Suspect the SC might be next. Seemed to start happening at about 15k miles for me, but I'm very light on the brakes.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #330332 31st May 2015 9:25pm
Ms. Mdx
United States 2015 Range Rover Autobiography 5.0 SC V8 Scotia Grey
Have a 2015 L405 V8 Autobiography and the brakes started screeching at 300 miles and 2 weeks of driving. Annoying and embarrassing. Took it back to the dealer and they replaced the pads with some redesigned, better or more heavy duty, pads. I now have about 3,500 miles and no brake noises so far. 2015 RR ATB (Scotia Grey w/Cirrus-Ebony)
2014 MB E63 s/AMG
2010 Acura MDX
Post #331205 6th Jun 2015 7:14am
