Home > In Car Electronics (L322) > Blinking Infotainment System L322 2007
Mc F
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Hi,
This has been a problem for over 6 months but now seems to be a permanent fault.
The sound whether on Radio or CD keeps getting cut every second or so!
Tried a hard reset by the local specialist British Off Road but they had no luck.
What do I need to replace as I need to resolve?
Post #329382 25th May 2015 12:31pm
Mc F
Are there any gurus out there?
Post #329729 28th May 2015 5:36am
Sounds like a loose connection to me.
Have you had a good fiddle (technical term) with all the connections in the left side of the boot ?
Post #329778 28th May 2015 12:02pm
ebajema
It does sound connector/cable related. The back of the dash unit also has a bunch of wires. I remember reading some radio issues on the forum in the past but that is quite some time ago. Suggest to try playing with search for a bit. MY 2010 5.0 SC Galway green and sand interior!!
Post #329796 28th May 2015 1:58pm
sako243
Check the Bluetooth unit, I had similar issues but more rapid and the Bluetooth had been drowned. Eventually gave up the ghost and had to bypass the unit with a bic Biro. Ed
Post #329832 28th May 2015 6:00pm
