Home > Maintenance & Mods (L322) > Td6 exhaust upgrade
Steveo
Td6 exhaust upgrade
Good afternoon all I was thinking of getting a upgraded exhaust for my car and may be a decat pipe can any body tell me if they have had this done and was there any improvement in performance or sound cheers again Steve
Post #329614 27th May 2015 1:42pm
mjdronfield
I understand if you decat it, it smells like an old ice cream van if you are near the exhaust.
A few on here have done it, and will be able to provide further info.....
Are we going for the 4 potato shooters under the bumper ? Should sound better than stock.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #329618 27th May 2015 2:24pm
jaybear
France
Problem with a diesel is that it will still sound like a tractor , even if in this case a Chelsea tractor ...... Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #329625 27th May 2015 3:16pm
mjdronfield
Can't hear my Chelsea tractor, as I have had the amp upgrade done and like my music Wink 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #329629 27th May 2015 3:33pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
De cats make them stink, sitting in traffic with the windows down is vile.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #329652 27th May 2015 6:17pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
And if you De cat it you'll have mot issues un less you swap it back every time Wink If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #329655 27th May 2015 6:40pm
Zirconblue
Actually my mate put a performance exhaust on his TDi Seat. It had no cat or silencer boxes in it. It's wasn't noisy at all! All you heard was a bit more turbo whistle.
What i would say though, it Diesels chuck out more soot, in fact i was following an X5 earlier, nice black sooty marks above each tail pipe on the rear bumper.
Post #329673 27th May 2015 8:24pm
Mikey
Mine passed its MOT without a cat this morning Wink
Post #329689 27th May 2015 9:22pm
IMO on a TD6 it is just not worth the effort or the expense.
You can always get the Carlos Fandango bolt on tail pipes (not actually connected to the exhaust!) .
Post #329703 27th May 2015 10:56pm
Re: Td6 exhaust upgrade
TD6 will stink without a CAT sir... A younger customer of mine had it done and it slowly smokes everything out!!! Thud
Post #329704 27th May 2015 10:57pm
Zirconblue
It will still pass the emissions test without one. However the tester is also supposed to visually check to see if a Cat is present, if the car had one when new. So it depends if he or she notices.
You can also get decats that look the same as a real Catalytic converter, the tester can't check the inside.
Post #329706 27th May 2015 11:00pm
