Home > Technical (L322) > Slow power drain |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Nothing to stop you disconnecting the battery -ve terminal and inserting an ammeter in between the battery -ve terminal and the end of the -ve cable end you have just disconnected.
23rd May 2015 8:53am |
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 |
Thank you. I like the idea of LED lights. Must I change the fittings or can they just be plugged in? |
24th May 2015 12:58am |
Replacement led bulbs can be obtained from eBay etc. no need to change fittings.
24th May 2015 5:33am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I can't remember without going to look at my car. But don't the interior lights 'fade out' when you lock the car?
24th May 2015 8:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 |
my smd panels fade out.... ... - .- -.
24th May 2015 8:29am |
All my interior leds seem to quite happily fade out. It's a good point about the possible shortened life through dimming but mine have been in 3½ years to date, if they fail I'll just replace them, they're not expensive. |
24th May 2015 8:55am |
As i said they'll still work, but the bulbs (or the dimmer) might not last as long.
24th May 2015 9:13am |
You've just about got it right.
24th May 2015 11:56am |
I was more concerned about the dimmer than the bulbs, as you say the bulbs are cheap enough (and if they do blow next week 3 years use from them isn't bad), but i'd baulk at buying a new ECU. |
24th May 2015 6:08pm |
Final victory. The Land Rover dealers charged me $80 to tell me that there was a power drain and quoted for a minimum of 10 hours and possibly 30 hours.
16th Jun 2015 9:11am |
The X5 has the same electric fan. |
16th Jun 2015 12:00pm |
