Home > General > Blue-tooth - Phone |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Not sure - not very tech minded - Would it be a deal breaker???
22nd Oct 2010 4:00pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
IT Lad, I thought you were into computers and IT
22nd Oct 2010 4:08pm |
iT LAD Member Since: 08 Jul 2010 Location: Surrey Posts: 1350 |
Thanks Vogue...
22nd Oct 2010 4:12pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
OK itLad, yes 2010MY has B/T - there is no cradle but in the centre cubby box you should find a cable plugged into a USB socket, and a second USB socket. The cable fits into an iPhone and allows it to charge on the move and to transfer all your tunes to the audio by cable, or you can download your tunes to a USB stick and plug that in as well and select that on the audio head unit. To use your phone hands free then switch on the B/T and pair it, all your contacts and recent calls/missed calls etc will be synched with the audio unit - I have found that on mine if I don't use the B/T then the head unit shows No Phone attached, even when the phone is connected to the cable, the B/T on the phone has to be on. None of this works with a Nokia/Blackberry............................. you have to plug into a cigarette lighter charger - the smart money have iPhones you see, so they can be hidden in the centre cubby along with the charging wires. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
22nd Oct 2010 4:21pm |
Your connect code will be 2121 to pair with the car ....... |
22nd Oct 2010 4:23pm |
Cheers Guys,
22nd Oct 2010 4:37pm |
No need Rob, the service indicator will tell you when it's due the first service, no point in asking as that is the answer you will get - but a voucher towards the cost of the first service might be worth asking for........ 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
22nd Oct 2010 5:05pm |
