Home > Technical (L322) > No response from transfer box
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Hi All,
Tried to select low range whilst reversing a heavy trailer a couple of days ago and no response. No fault codes, no noises, nothing. Hi range absolutely fine. I haven't used low range for probably 4 months, was fine lost time. It has had a service including a transfer box oil change in that time.
Any ideas? Couldn't see anything very similar in the search results......
Thanks Jon.
Post #329171 23rd May 2015 4:32pm
Weegie
Probably too obvious but were you in neutral when you tried? It can be easy to forget. John
GAP iiD BT
Post #329173 23rd May 2015 4:35pm
jon3929
Laughing I have done that before..... but yeah it was definitely in neutral and correctly registered so on the 4x4 screen.
Cheers Jon.
Post #329175 23rd May 2015 4:40pm
Zirconblue
There's an electric motor on the box that changes the range, if they're not used much they seize up.
If you can get at it you can check it has power to it, if it does you'll know it's the motor.
Post #329191 23rd May 2015 7:07pm
jon3929
Sorted
My Indy plugged in, recalibrated the transfer box control unit - sorted
Probably the result of having disconnecting the battery a few months ago.
Happy days Thumbs Up
Post #329983 29th May 2015 9:05pm
