Home > General (L405) > L405 Bonnet - takes a bit to open and close |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi, wondering if anyone else has had this issue. The bonnet on my car is not the easiest to shut, on my L322 you could either drop it from around 6inches up and it would close or lower it down then just give a short /sharp push on it and it would close completely. On my L405 however, I currently have to drop it from around 10-12 inches above to get it to close and I cannot get it to lock in by just pushing on it when almost closed. Releasing it is also an issue as the lever you pull upwards has such a short range of travel on it and the latch does not quite clear the mechanism. I have spoken to the dealer and its going in at some stage to have it adjusted, but also I noticed the front of the bonnet on the passenger side is around 2-3mm further back than that on the drivers side and as such, the passenger door catches it slightly when opening (the tolerance seems minimal compared to the L322). I also notice that to lift the drivers side windscreen wiper when washing the car, it has to be pulled upwards initially else it catches the back of the bonnet (another one where it is only millimetres) if I try to lift it. Assume this is just due to the bonnet position again. Dealer says this is a 2 day job to adjust the bonnet !! Anyone else had this issue? Steve
14th May 2015 1:22pm |
Cheers Alistair, nice to know it takes more to close, I'll see what mines like once adjusted , hopefully easier to open and viable to close from the 'latched' position which is how I prefer to do it. Steve
18th May 2015 12:35pm |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 |
Mine is the same If you have nothing nice to say,say nothing at all. |
18th May 2015 12:54pm |
What they need to do is have a 'soft close' bonnet, much like the car doors, that you simply lower down and it automatically pulls it the rest of the way and locks it in. Obviously there would be a manual override somewhere (like the fuel cap release) and then a button you push to release it under normal circumstances in the car that is automatically disabled when the car is in motion. Don't think any car manufacturer has thought of that yet? No doubt someone will prove me wrong Steve
19th May 2015 9:22am |
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 |
I thought I had shut the bonnet as normal but when driving I could see the drivers side lifting, asked the passenger and they could see nothing. I was going to contact the dealer, but I thought I would have a look. Yes I was a noob…..
25th May 2015 8:07am |
Forgot to say folks, car went into Main dealer to have bonnet adjusted and now works fine. Releases a lot easier and I can now close it by lowering it down until the release latch clicks, then simply give the bonnet a quick light push and both of the other latches lock in fine, no more dropping the bonnet. So now working as per the process in the owners manual Steve
29th Jun 2015 3:50pm |
