Home > Camping, Caravanning and Holidays > Tin Tent imminent
Page 3 of 3 <123
steadyaway
Thanks for the info, but when I had the tow bar fitted I took the car for programming. The guy who did it specialises in Land Rovers and he said there was no configuration files on the car to enable him to do it, or is it in a different location? The fact that the other road lights work would support the claim that on the 2006 ff it is plug & play.
Post #327744 13th May 2015 5:59pm
generally the lights will work anyway, does the PDC deactivate when the van is plugged in? There is nothing that can't be fixed with a hammer😜😜
Post #327745 13th May 2015 6:03pm
steadyaway
Yes, rear sensors deactivate but I don't know about the front ones.
Post #327754 13th May 2015 6:39pm
miggit
The front PDC's should remain working, I had an intermittent fault with my rear PDC and the only time it didn't give me the audible up yours, was when I had a trailer plugged in Shocked and then the front would swear at me when I got too close to something in front Shocked Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #327780 13th May 2015 8:01pm
steadyaway
So what should happen with the EAS? Should the lock lamp illuminate, will it just refuse to change height or will it work as normal?
Post #327800 13th May 2015 9:11pm
miggit
On my car the lockout light comes on and I'm stuck in normal height mode, I don't know how the face lift cars respond, seeing as they are Ford 'puters not Beemer.
I know that mine will not change height at all, I've tried, and it didn't work, so I had to unplug the trailer so that I could drop the EAS, to clear a dip with the trailer. I wish that they locked the height at speed, not totally, cos when you is offroad it can be handy to adjust the height so as not to ground out the rear of the trailer, or the front when going up a hump. Yesterday I couldn't spell Engineer... Today I are one!
Post #327834 13th May 2015 10:52pm
Page 3 of 3 <123
