Home > Maintenance & Mods (L322) > What can be done to stop top tailgate corroding? |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
As in the title, what can we do as a preventive measure? I've looked at mine & on close inspection I'm sure I can see it & im thinking I want to do something now to stop it. 2004 RR 4.4 V8 Autobiography |
7th May 2015 10:05pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8164 |
Fill the bottom with something like this
7th May 2015 10:16pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
To be fair Waxoyl is cheap and works ok.
8th May 2015 7:27am |
Does it set like waxoyl? Craig you say not to do it with tailgate open then close, are you saying leave it open till it sets? 2004 RR 4.4 V8 Autobiography |
8th May 2015 8:33am |
Sort of, it skins over, which means its more resilient. Waxoyl eventually dries out and needs re-treatment after a few years.
8th May 2015 8:53am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Answered above |
8th May 2015 9:18am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3766 |
I did this, my thinking was you want it to set in the bottom and the drain holes to be clear. So I sprayed liberally whilst open (you can't really do anything else) and closed after having taped paper (I used old wallpaper) over the lower tailgate and bumper (under where it would drain out) and then parked in the street so the Dinitrol didn't drip on my drive.
8th May 2015 9:34am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Would it not be possible to spay with the tailgate shut.... maybe with the lower tailgate open and some well placed rags / buckets / FREE PAPERS (at last a use for the bloody things ). and to gain access, maybe entry from the rear door with a seat down?
9th May 2015 10:41am |
