![]() | Home > Maintenance & Mods (L322) > Wheel Arches |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Loads of info on this...
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
What sort of perverted Forum is this??? ![]() 20 years ownership of Solihull products, ALL GONE NOW, sniff! Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee. Previous: TD6 HSE L322 Auto FF 2.5 TDi 4-door Classic Disco II And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic Not to mention the Lada Niva before those. (I said not to mention it!) |
To be fair I didn't expect naked arch pics.... But there you go.
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
Perfect, just what I needed!
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
I spotted this on mine last week when i was washing. it had been repainted before due to rust and the paint was starting to flake and could see the orange underneath. This area is far to exposed to just have standard paint and lacquer, it docent stand a chance against the stone chips and abuse it gets. As standard on BMWs on the inner side of the wheel arch it is coated with stone guard ( very thick rubber like paint often seen on car sills ) . so thats what i done with mine, buffed back the rust which really wasn't bad just surface rust then acid etched, primed then blasted it with stone guard through a shoots gun aresol stone guard could be used but its nowhere near as thick. i just masked off to the edge line. see how it goes i was going to put the rubber strips on but to be honest i don't see anything coming through the stone guard. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It does seem to be a design flaw really. The plastic wheel arch liners should have be designed so they they covered this area, like they do on many cars, this would also stop the mud from getting behind that lip too. |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
My arches have started to rust and bubble. Whats the best way fix ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
mine too, I got a mini grinder on them, took back to bare metal, special primer and hand painted smooth silver hammerite which is a near perfect match on my Zermatt silver, looks quite respectable and if it does it again in the future I will just repaint |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
Mine is also rusty. What I'm going to do it grind back with a flapper wheel, treat with rust treated then paint in epoxy mastic, then stone chip followed by a coat of black Hammerite. I can't see much getting through that lot. 2004 RR 4.4 V8 Autobiography |
