Home > Maintenance & Mods (L322) > HEATED SEATS FFRR
Emirates777 wrote:
Andy B
Your a STAR - thanks
I wont say anything to my dealer - as they are good at what they do - I just think its someone there who does not know this - but the main thing is - that I now know
That's what make this forum - "worth its wait in gold" - someone knows something
Cheers Andy B Thumbs Up
Should just be the filters they change on major services sir... 2 in each seat Thumbs Up
Post #326226 5th May 2015 11:55pm
miggit
I did say unlikely Wink
Although I have just found out that it's possible to a 70 deg C difference between the 2 sides of the plate, but the heat / cold has to be dissipated for this to happen. So even assuming that L/R were able to get 100% efficiency ( Rolling with laughter ) that still aint gonna start a fire Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #326233 6th May 2015 12:11am
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
northernmonkeyjones wrote:
see crags post in the thread mentioned above, it refers to a filter in the heated and cooled seats, this requires changing as part of the service schedule, maybe that is what they are referring to, and not the element itself. Worth checking.
Hi northernmonkeyjones
Thanks all for the reply's - I have read these all
I am beginning to think - " as he ( the LR service guy ) got the 3.6 model car, who I believe has only got heated seats - ie No Tea bag seats, mixed up with the 4.4 version !
Is this what he may have been thinking - does the 3.6 FFRR have to have the elements serviced ??????? - or what was he getting mixed up. He did say to me the HEATER ELEMENTS HAVE TO BE CHANGED IN THE SEATS - that was clear as anything, when he said it - as I thought at the time ...... Oh Censored my seats leather will be all over the place.
It was worth starting this thread - as someone has already said - if you go to a dealer and they say the same to you - at least you will now know - as I didn't at the time.
and dont get me wrong - I love my dealer - but there's things that get changed or wrong info given - we are all human
I now know the 4.4 with the Tea Bag Seats are heated by the engine
Post #326247 6th May 2015 8:12am
Emirates... You 100% DO NOT have seats that are heated by the engine sir!!!
You have 4 peltier units in your front seats! One in each base and one in each back! The peltier units or MINI FRIDGE/OVEN units (as i refer to them when explaining to my customers) have a FILTER that looks much like the make up removal pad my wife uses nightly! The filters are replaced at big services NOT the peltier heater! (as that would cost around £3000 Shocked )
Hopefully that is now crystal clear Very Happy Bow down Thumbs Up
Post #326250 6th May 2015 8:41am
EmiratesA380
Cam-Tech-Craig Thanks
Are the FILTERS you mention easy to replace your self ? - as I would like to replace these my self on a regular basis - as I like to look after my cars more than most
How much are they ? - have you a part number ? ( saves ring my dealer )
thank again
Post #326254 6th May 2015 8:52am
IMHO nothing is very difficult on the FFRR Shocked
But to be honest, changing the filters mean removing the rear leather cover/map pocket panel of the seats! If you are happy with that then yes they are easy enough replaced at home... There are one in each rear (obvious when you remove the panel) and one under each seat (again obvious when you kneel down and look under your seat sir)
Bung Ducky Dan a PM and I’m sure he will quote you happy Thumbs Up
Post #326260 6th May 2015 9:07am
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
Where are these filters listed in Microcat? I cannot find them in heater nor in seats section? Maybe I'm missed them?
Or what part number do these have? Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #326287 6th May 2015 10:30am
EmiratesA380
Hi Edfors
I have done more research today - hope this helps you also
A bigger pic to help read:
Post #326384 6th May 2015 5:43pm
Edfors
Thank you! Bow down Found it now in my Microcat as well!
Post #326418 6th May 2015 7:44pm
