Home > Maintenance & Mods (L322) > Steering free play
Zirconblue
Steering free play
I've noticed mine has a small amount of free play in the steering wheel.
Should it be fairly tight on the steering? Being as its rack and pinion not a reciprocating ball.
Or is it like old Land-Rovers where they had a certain amount of free play by design to stop it snatching too much when off roading?
If this a fault, then is there a favourite wear point on these? I take it there are some UJ's in the column.
Post #325560 2nd May 2015 5:28pm
There should be no noticeable play in the steering, the column UJ'S are unlikely to wear, first thing to look at is the track rod ends, then the rack itself, it has replaceable ends that wear as well, these usually squeak when they are worn, if not it's the rack itself. A badly worn suspension joint could also give you play...
If you want to check the track rod ends then get someone else to rock the steering and you should be able to see play in them... Pete
Post #325566 2nd May 2015 6:15pm
Zirconblue
Sounds like it's probably the track rods or the track rod ends then, will have to climb under there and have a feel. It had an MOT a few weeks ago, nothing advised on it. But with all the pot holes around something could have given up.
I know on Merc Sprinters, the UJ's in the columns used to wear and cause the same symptom.
Post #325572 2nd May 2015 7:13pm
Inner track rods shouldn't give too much play, as they don't need to be too far gone to give noticeable problems, probalbly a ball joint somewhere, either the track rod ends, the bottom arms or the upper arm ball joints. (Lots of ball joints in the system). There is nothing that can't be fixed with a hammer😜😜
Post #325592 2nd May 2015 8:12pm
Discotigger
Check that the nut that locks the lower steering column to the splined shaft on the steering rack is fully tightened up. If the nut is slightly loose, it can cause the steering play you're talking about.
Best place to check first, as there's been threads on this before. Thumbs Up
Post #325593 2nd May 2015 8:36pm
Zirconblue
That makes sense too, will have a look at that while i'm at it.
Once i've got this ironed out i can get the 4 wheel alignment done.
Post #325603 2nd May 2015 9:01pm
As above, should be none sir Bow down
Post #325626 2nd May 2015 10:48pm
Zirconblue
Yep, steering column to pinion pinch bolt needed nipping up, no more clunkyness. Just have to get the 4 wheel alignment done now.
Post #325829 3rd May 2015 6:48pm
That was nice and cheap then.... Thumbs Up Thumbs Up Pete
Post #325830 3rd May 2015 6:49pm
Zirconblue
had a good look at all the joints and bushes under there and they all look sound. Noticed the ABS lead and brake hose on the OSF needed clipping back into their mountings on the strut while i was under there.
Looks like i have a coolant leak on the back of the engine, there is a bit of it around the bell housing/transfer box guard. The local Main dealer told me there is a common leak on the back of the cylinder heads, some sort of plastic union there that goes.
Post #325835 3rd May 2015 6:55pm
