Home > Technical (L322) > Lifting a FF on a 2 post lift? |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 |
Hi Folks.
1st May 2015 4:20pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8283 |
Had mine on one loads of times, never had any problems, always comes back to land at the height it was when raised... Pete
1st May 2015 5:08pm |
Thanks Guys.
1st May 2015 10:21pm |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 |
I've lifted ours with no issues. The only thing is to remove the deployable side steps if present, to get access to the lifting points.
2nd May 2015 7:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Why remove deployables??? They stay out with a button sequence sir |
2nd May 2015 7:39am |
OK, probably possibly with another lift, on our lift the steps will foul the arms of the lift. Guess I could use some taller lift pads. Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
2nd May 2015 7:44am |
Ahh now i understand!.. Mine has three different lengths of pad extensions so the arm's are kept well away from deployed steps |
2nd May 2015 7:48am |
Yes mine has deployable steps, silly question
2nd May 2015 8:35am |
Is the procedure not in the WIKI? |
2nd May 2015 8:47am |
What sort of ramp is that Edfors? I have just installed a 4T Automotech in my unit.
2nd May 2015 8:51am |
Thanks Craig I will have a look.
2nd May 2015 8:54am |
Nussbaum 3 tonne Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
