Home > Maintenance & Mods (L322) > Seats compatibility
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Seats compatibility
Does anyone know if a set of front Vogue SE seats from a 2012 will fit a 2008 Vogue. Not worried about the ventilation function just need electrics and heated seat bit to work. From what I understand (bit limited) the SE seats do not have a heating element however could it be swapped from the Vogue seats or alternatively is the cabling there behind the dash switches that would allow you to change out the Vogue switch panel for a Vogue SE panel.
Tried the 2012 (style)seats and so much more comfortable, the 2008 ones are giving me a bit of a back problem (recurring old problem) and thought the newer style may help. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #325117 30th Apr 2015 11:20am
Chillb
ie Would this fit.
http://www.ebay.co.uk/itm/Range-Rover-Vogu...4638bb3155 Porsche 993 Targa, Buick Skylark Convertable 1968
Post #325119 30th Apr 2015 11:37am
craig-meister will be able to tell you... ... - .- -.
Post #325121 30th Apr 2015 11:43am
mzplcg
From personal experience of re-foaming a 2007 VSE seat, they DO have electrical heating and Air-Con linked cooling. But the 2010 onwards VSE seats I *believe* (and Craig can probably keep me honest here) the heating is not electrical but linked to the heating and ventilation system.
If I am correct you would have some challenges to overcome. You would have the electrical connections for heating as Vogues had heated seats. But you wouldn't have heating elements in the seats themselves. Yes, you could probably swap them over but note they are delicate (with a capital 'F') and easily broken.
Good luck though.
Post #325122 30th Apr 2015 11:49am
Chillb
Ah yes, if there is man that knows all Bow down he would be that man Thumbs Up Porsche 993 Targa, Buick Skylark Convertable 1968
Post #325123 30th Apr 2015 11:49am
Chillb
mzplcg, thank you. Was a bit worried about the heat, could live without the ventilation.
Hopefully can touch base (no pun intended) with Craig later on the feasibility of the swap Question Porsche 993 Targa, Buick Skylark Convertable 1968
Post #325126 30th Apr 2015 11:57am
Chillb
Craig hi
Not sure if any advise on this one.
Thank you Thumbs Up Porsche 993 Targa, Buick Skylark Convertable 1968
Post #325207 30th Apr 2015 9:09pm
Chillb
Apologies, advice Whistle Porsche 993 Targa, Buick Skylark Convertable 1968
Post #325208 30th Apr 2015 9:09pm
Not really compatible I'm afraid sir Sad
Your Vogue has electrical elements to heat them whereas the VSE seats have an air heater/cooler in the base and another in the seat back... So, retro fitting the heating/cooling feature would be a mission as they have different looms!
To make things crystal clear! If you had a 2007 VSE then yes you can fit 2012 VSE or AB seats BUT only if the car is equipt with the air heated/cooled feature!
Sorry sir Embarassed
Post #325227 30th Apr 2015 10:49pm
Chillb
Thank you, suspected the same Sad
Would standard Vogue '12 seats fit a standard Vogue '08 then, ie just seat heat only Question Porsche 993 Targa, Buick Skylark Convertable 1968
Post #325239 1st May 2015 5:55am
Yes but they are the same seats Whistle Whistle Whistle
So, how would you benefit? Are yours crushed? Deformed in some way?
Post #325271 1st May 2015 8:41am
Chillb
Apologies missed your reply Embarassed
Sat in a 2011 and seats looked different and were very comfortable, with mine seem to get a numb left thigh as the bolster is so high. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #327976 14th May 2015 8:29pm
