Home > Maintenance & Mods (L322) > Anyone around Glasgow that can reset service light ?
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
is there anyone on here in or around glasgow that has the equipment to reset my service light ? From what I have read online it cant be done through the trip computer and has to be plugged into iid or similar . Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #324963 29th Apr 2015 3:15pm
Your local National tyres should be able to it as some of their branches have started doing diagnostic work on cars at a cost ====================================
Post #324991 29th Apr 2015 5:11pm
markcaughey
Is it just a general diagnostic machine that's needed ie not something LR specific ? I know a few guys that have that kind of equipment for general fault reading and clearing etc Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325003 29th Apr 2015 7:09pm
Mikey
I'll be in Glasgow on Monday if you need it done Thumbs Up
Post #325011 29th Apr 2015 7:57pm
A11EXU
Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND
Scotland 2004 Range Rover Vogue Td6 Adriatic Blue
I am close to Glasgow (work in Govan) stay in Bishopton and have a Hawkeye if you need a shot? Thumbs Up '54 Adriatic Blue Vogue
Post #325183 30th Apr 2015 7:47pm
markcaughey
thanks guys. Mikey that would be great Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325522 2nd May 2015 1:12pm
Mikey
PM me an address or phone no Thumbs Up
Will be in Glasgow from 9 until probably 2
Post #325524 2nd May 2015 1:32pm
Discotigger
Just found this info from a Google Search, covers the 2002 to 2004 Model FFRR L322
I've used this procedure on my FF an MY05 model with touchscreen satnav
Service light reset - Land Rover The procedures described below are relevant to the following European specification models: Model Chassis Model year Discovery 3 / LR3 L319 2005 to 2006 Range Rover L322 2002 to 2004 Range Rover Sport (not supercharged) L320 2005 to 2006 1) Procedure to check/reset service status - Distance counter �� Switch ignition OFF �� Press and Hold left instrument panel reset button, switch ignition ON to position 'I' (accessories) �� Keep reset button pressed for approximately 5 seconds until the LCD displays 'RESET SIA'. The distance to service (e.g. 2150 miles) and the service type (e.g. Inspection/oil service) will be displayed. �� Has the 'Reset Distance' limit been reached or exceeded? o NO - Follow instructions in section 2 below o YES - Follow 'Reset Distance Counter' instructions below Reset Distance counter procedure �� Press and hold left instrument reset button for 5 seconds. 'RESET' will begin to flash on the LCD display. �� To reset distance the left hand button should be pressed before the 'RESET' message has flashed 5 times �� The LCD will display 'END SIA'. Switch ignition off 2) Procedure to check/reset service status - Date counter �� Press left instrument panel reset button once �� The LCD will display 'RESET SIA' followed by the service due date. �� Has the 'Reset Date limit been reached or exceeded? o NO - Press the left instrument button once. The LCD will display 'END SIA' to indicate the service interval check/reset procedure has been cancelled. o YES - Follow 'Reset Date Counter' instructions below Reset Date counter procedure �� Press and hold left instrument reset button for 5 seconds. 'RESET' will begin to flash on the LCD display. �� To reset distance the left hand button should be pressed before the 'RESET' message has flashed 5 times �� The LCD will display 'END SIA'. Switch ignition off
May be worth a try Thumbs Up
Post #325544 2nd May 2015 4:16pm
Mikey
Doesn't work on 06MY Thumbs Up
Post #325556 2nd May 2015 6:00pm
markcaughey
Pmd Mikey Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325912 4th May 2015 9:49am
Mikey
Got it. Just finishing up in 20 mins or so, then be in touch Thumbs Up
Post #325935 4th May 2015 12:13pm
