Home > Technical (L322) > Lazy Locking
supershuttle
Lazy Locking
On my 2007 pressing and holding "lock" on the key closed all the windows AND the sun roof, the converse being true when unlocking.
However on my 2009 (MY2010) the windows open and close but the sunroof isn't affected, it remains in whatever position it's in.
I've messed around trying to change things with the IIDTool to no avail - am I flogging a dead RR? So to speak Rolling with laughter Geoff
Post #324978 29th Apr 2015 2:49pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
The sun roof should be activated. My old 02 did and I've just tried my 60(11MY) and it does so can't see an 09 being any different.
Incidentally - just found out you can let go of the button now and the apertures will continue to move but on my 02 you had to hold the button down until movement was complete.
Hope this helps. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #325010 29th Apr 2015 6:51pm
supershuttle
mmm.... interesting, still can't make it do it - works fine on the switch and all the windows work except the rear drivers side that always sticks every couple of inches. Geoff
Post #325013 29th Apr 2015 7:08pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Does it auto close/open with a flick of the switch inside the car (rather than by holding the button till closed)
It may need resetting for the auto function to work. Using the button inside, fully open it holding the switch and then fully close it, again holding the switch. Once closed, let go of the switch and then press the switch and hold for a second (as if to close it again even though it is closed)
This should set the fully open/fully closed positions and may then work with the auto closure feature.
I can confirm my MY10 does auto close everything. Ash
2016 SDV8 AB
Post #325015 29th Apr 2015 7:30pm
supershuttle
No joy as yet but it's getting cold outside, yes the sunroof works one touch fine but although the windows open and close using the key the sunroof remains where it is - open or shut.
The rear window of the drivers side needs repeated pressing of the internal switch to open and close completely - only moves automatically for a few inches at a time before I need to dab the switch again.
Still it isn't really anything serious, just annoying Very Happy Very Happy Geoff
Post #325021 29th Apr 2015 8:13pm
comports
Do the reset procedure on the rear window as well. All the way down pressing the button, all the way up pressing the button then once closed, hold the switch as if to close it for a second or two.
I had to do it on mine once the battery was reconnected.. Ash
2016 SDV8 AB
Post #325026 29th Apr 2015 8:18pm
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Lazy lock
Had lazy lock Actived but nothing happens 2006 model any tips what to do
Post #325154 30th Apr 2015 4:28pm
