Home > Technical (L322) > IID Tool BT and disco 3
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Embarassed
I bought a second viin code for my mates disco 3 and activated it so he could change a few things on his car... (indicator 3 blinks, dlr etc)
None of them worked and now his radio is stuck in Phone Mode and won't work.
How do I feel now..... I broke his car.... Ash
2016 SDV8 AB
Post #324532 26th Apr 2015 4:00pm
chex
Kenya
IIRC the firmware for the IIDTool is different for the FFRR and the Disco.
Post #324549 26th Apr 2015 5:05pm
battery disconnection Ash? worth a try..
or you should be able to restore to original settings. ... - .- -.
Post #324550 26th Apr 2015 5:06pm
comports
Hi Chex - The IID BT is compatible with multiple vehicles so should be ok.
@Stan - will try that but he has gone away my charge to recycle his battery - I've read some posts that suggest low voltage sends it into power save mode. After that will try the disconnect or fuse 53 pull.
Just feel bad cos it was fine before we started.... Embarassed Ash
2016 SDV8 AB
Post #324564 26th Apr 2015 5:53pm
did you not have the engine running? ... - .- -.
Post #324577 26th Apr 2015 7:50pm
comports
no - can't when updating the CCF. It wants to turn the ignition off and on and ask that the engine is off and ignition is in the on position.
Having read further docs, it appears that the ECUs have to be flashed to the latest version for the updates he wanted but will wait until it has a full battery charge before trying... I hope he's not too miffed about not being able to use the stereo though
Big Cry Ash
2016 SDV8 AB
Post #324579 26th Apr 2015 7:56pm
must be different for the disco cos you can [and its best to] have the engine running when you play with the ccf on the FF.... ... - .- -.
Post #324582 26th Apr 2015 8:21pm
Zirconblue
Land-Rover dealers have a 'battery support unit' hooked up to the cars when they're doing a diag session. It's basically a mains battery charger with additional stuff to prevent it frying electronics. Hooking up a second battery with jump leads would have a same effect though.
Post #324604 27th Apr 2015 6:21am
comports
Thanks Zirconblue...
I read that also so may try with a second battery if needed.
It does seem a shame that no matter how good out cars are, it's an issue if we "have the doors open to clean the inside" cos the battery can't handle it..! I suggest LR need to look at not starting up all the electronics unless the engine is turned on. Can't see me needing things like air suspension or cameras etc just to sit in the drive... Ash
2016 SDV8 AB
Post #324605 27th Apr 2015 6:46am
Martin
Site Admin
Drop GAP an email or PM, they will help you.
Post #324614 27th Apr 2015 8:58am
comports
WOW - Thanks Patrick for all your assistance tonight. Went through various things and resets etc... all guided by Patrick and now my mates D3 is all up and running. All updates made (DLRs, clock on display, 3 flash etc) and his radio is back again.
I take my hat off to Patrick from GAP - he knows his stuff and is more than willing to help out when things go bad.
A really great team over there...
Many Thanks Patrick...!
Ash Ash
2016 SDV8 AB
Post #324687 27th Apr 2015 8:24pm
glad its sorted for you Ash and kudos to the GAP chaps.. ... - .- -.
Post #324689 27th Apr 2015 8:29pm
comports
cheers Stan -
They certainly are a good crowd - That's what I call customer service Thumbs Up Ash
2016 SDV8 AB
Post #324691 27th Apr 2015 8:32pm
Mikey
Patrick and the guys at GAP even went as far as adding in a few options into the CCF options, to rectify issues caused by another diagnostic tool. And they were only too happy to help.
I suspect they like the challenge! Laughing
Post #324697 27th Apr 2015 8:45pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Always a pleasure Thumbs Up
Post #324701 27th Apr 2015 8:48pm
