![]() | Home > General (L405) > Filling the void in the boot |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8542 ![]() ![]() ![]() |
10cm wider but it looks like there is some space at the side on the pic.....
J600.COM Member Since: 27 Dec 2009 Location: North East Posts: 113 ![]() ![]() |
I spotted quite a few that were 50cm wide but when I measure it would have been slightly too wide
KeithG934 Member Since: 31 Jan 2014 Location: Burnley Posts: 25 ![]() ![]() |
Back-to-back heavy duty Velcro? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Do you have some heavy duty velcro that will stick to the carpet in your car ? The stuff that holds mats in place isn't enough as it's got to hold this in a vertical position. |
I've ordered one, so I'll experiment when I get it. I always use heavy duty Velcro for my personal number plates in doubled up back-to-back format - don't like screw holes! |
Ordered some: Velcro Heavy-Duty Stick On Tape 50mm x 1m Black VEL60241 https://www.amazon.co.uk/dp/B00186Q9AK/ref...pvb1N8KR7K
Good luck |
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
4 screws and suitable 'washers'...... Job done!
that looks spot on, where did you get that net? |
hi, from my old L322! |
As luck would have it - I have a couple of those ![]() Good job I hadn't got around to posting in the For Sale section yet ![]() I was unsure about drilling holes, but if the velcro doesn't work out, then it will be the only solution Drop me a PM with your address and the other one is yours |
That'd be awesome thank you very much |
jpr Member Since: 12 Aug 2008 Location: North East Posts: 63 ![]() |
nice little bag this, ordered one for my L405 and ill see what method i can grasp with to secure and post results ---------------------------------------------
