Home > Maintenance & Mods (L322) > service item " lubricate top edge door seals "
viper
Vaseline ?
Post #324445 25th Apr 2015 10:41pm
No no no... Vaseline is for your boyfriend, you need GUMMI PFLEGE
Post #324447 25th Apr 2015 11:10pm
Laughing Previously..
Post #324448 25th Apr 2015 11:11pm
I use this Thumbs Up
Post #324463 26th Apr 2015 7:48am
viper
Laughing
Post #324480 26th Apr 2015 9:59am
viper
I guess the seals dry out and leak , which is what they are doing now.
is the wickes stuff really ok?
Post #324481 26th Apr 2015 10:01am
Works fine - I do mine once a year when I put my winter wheels on - easy to do - just apply to a rag and wipe around
I was told vaseline is corrosive for the seals so not to use that - the gummi stuff is supposed to be good too, but not tried that.
Post #324489 26th Apr 2015 10:57am
Zirconblue
Vaseline isn't the best stuff to put on rubber seals.
The silicone lube isn't a bad idea.
Their roof and gutter sealant is also a good non-setting windscreen sealant. Wink
Post #324497 26th Apr 2015 11:21am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Gummi also improves the appearance as well as protects. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #324556 26th Apr 2015 6:36pm
Laughing Getting a bit OCD when the appearance of your rubber door seals starts to matter Whistle
The Wickes stuff makes them a bit blacker & more shiny - if that's your thing....... Rolling with laughter
Post #324592 26th Apr 2015 10:26pm
viper
thanks for the GUMMI tip , not too bothered about the appearance but its a service item that I want to keep up and my door seals will benefit from being a bit quieter.
There is a winzer wurth right near me so I can pick some up
Post #324593 26th Apr 2015 10:38pm
ajac8
I suppose its all about personal preferences. Personally I like mine to look its best. Cant see the point otherwise. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #324640 27th Apr 2015 5:30pm
