![]() | Home > Technical (L322) > Varta H15 020 AGM Battery |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 ![]() ![]() ![]() |
I'm surprised a diesel only had a 90ah one in anyway....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8621 ![]() ![]() ![]() |
Have you checked you alternator voltages. If you haven't changed it it could be starting to go. The Varta is pretty much the same battery as the bosch. There is nothing that can't be fixed with a hammer😜😜
sodalis Member Since: 18 May 2014 Location: Flintshire Posts: 26 ![]() ![]() ![]() |
Yes, I have and it's fine.
that good, mine is perfect on the Bosch and can run the FBH but so long as it has a 15 min run after. |
Glad to hear it |
walterdned Member Since: 21 Feb 2016 Location: Perth Posts: 3 ![]() ![]() |
Good Afternoon,
Hi Walter,
Good Evening Jack,
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 ![]() ![]() |
Did mine yesterday, best of luck! |
Ah, Good Afternoon All and specifically Sodalis and Mr Tee, well I have tried and tried to fit the Varta H15 battery but the problem is the "automatic battery disconnect" which is fitted on the positive terminal and which sits down the side of the battery which means that I simply do not seem to have enough length to fit the battery, of course in all other respects there is no problem in fitting it. Could you let me know if you had this problem or not and if so how you got around it.
