![]() | Home > Maintenance & Mods (L322) > Subframe Corrosion... Big Repair Bill ££££ |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Sorry to hear of your woes. Try to locate a second hand subframe from a breakers yard. I am sure you could pick one up for around £100 or so.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
You don't have to remove the engine to replace the subframe, it's not a very big job at all...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Has it always been in Scotland? Rust seems to get worse the further North |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
After I put the deposit on mine, I got my hands on the MOT. Advisory on front sub frame corrosion starting. I said I wasn't buying a rust bucket so they removed the subframe and had it cleaned up and powder coated. No engine out and no rust 4 years later.....
As Craig said Scottish Land Rover seem to rust a lot quicker than those further south. I have seen quite new D4 from North of Scotland with severe rust under the rear end.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
I'm not surprised cars from up here suffer more than those 'darn-sarf' - We get so much salt grit put on our roads during winter that it isn't funny.
Having lived in Edinburgh and the Scottish Borders for twenty odd years I would agree, the use of salted grit in winter seems to be excessive. As a result I would honestly not buy a car from Scotland if you wish to keep it for a few years, the risk of corrosion on the underside of them imo is too great. I know I was endlessly greasing the underside of our cars when there to avoid corrosion, much to the amusement of my neighbours. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
My previous RR, 2002, had rust on the front subframe so I cleaned it up and it got a regular coating of waxoyl.
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
Interestingly, I only bought the car in January and collected it from Brighton (from a forum member on here) - I believe it lived most of its previous 13 years down on the south coast! So Scotland can't be blamed for the corrosion this time - not sure why it's so bad then...
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
plenty of decent looking frames on ebay
FYI, All the subframes will fit your car sir... The engine & body mounts for all models are the same! The 4.4TDV8 subframe for instance, has extra exhaust hangers attached but is fundamentally the same subframe (engine & body attachment) So would fit a TD6 or old type petrol for example... The only difference is the front cage (bumper attaches to it) 02-06 then 06-09 then 09> so 3 different front cages! Yours may well not be written though? Bolts to the subframe using two bolts |
Wouldn't buy a car from the seaside neither sir ![]() We went to Tenby for a weeks holiday and there were 12 & 13 plate Defenders on the harbour side that were ROTTEN!!! & i mean chassis blown apart with rust! Bumpers with holes in! |
^ That's why I'm always coating the undersides of my cars with grease. |
