Home > Camping, Caravanning and Holidays > roof bars for roof tent |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
you can certainly mount a third sports bar, but the way I had to do it was to find an odd one on ebay, and dismantle it and cut it about 40mm shorter. (all three mount points are different gaps!) but this only gives you three fixed position bars. I then decided I wanted more flexibility, and I bought a set of adjustable rails, that you can add two pairs of sliding bars to. that adjust in length with the small tools you get with them. they have a 95kg rating I believe. (sticker on top says so) they take about 20 mins to clip on. they are not completely (infinitely) adjustable, but you can set them in gaps around 6 inches apart. I got hold of the rails, (second hand genuine) first, then kept an eye out for the bars (pairs), again genuine. you can buy a set of rails and a pair of bars that are aftermarket, but people I have heard don't really rate them, but they do look very similar, (cost around £160 against around £700 for a genuine new set!) but I don't think they have the silver sticker, and part number on them. here is an old pic of all four on my steed.
12th Apr 2015 10:15pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Rhino Rack will give you the most versatile option for roof bars and will be flat with three bars instead of following the roof curve and you wont have to cut of the little doors on the roof to fit it .
13th Apr 2015 4:09am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7954 |
No reason you couldn't put 3 or 4 Thule bars on either. |
13th Apr 2015 8:27pm |
Thule bars like many others are not specific to the Range Rover , if you fit three or more bars then you follow the curve of the roof and for a roof tent I'm sure flat would be more comfortable . 2008 MY Supercharged
14th Apr 2015 1:00am |
I agree with JohnBoy re. the rails and multiple bars. Also what Axle mentions, the flat type bars would make it nicer for the tent to fit although maybe you can get spacers to sort that out. I have never seen that type of roof tent up close.
14th Apr 2015 6:51am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Why not bolt steel box sections into the existing screwed roof mounting points when required for the tent.
14th Apr 2015 7:23am |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 |
thank you all for your replies!
14th Apr 2015 9:18am |
Good luck, they look like quite good rooftents MY 2010 5.0 SC Galway green and sand interior!!
14th Apr 2015 10:31am |
Good point - I've never really thought of the roof as curved, but I guess it is to some degree. How do the rhino bars work differently? Is each one height adjustable ? Or does it come as a set of multiple bars and each one has to be fitted at a specific point ? |
14th Apr 2015 10:46am |
The Rhino three bar set up is specific to the for the Range Rover and is a specific part number , the middle bar sits lower so all three line up flat you then choose which type of bar you want i,e, vortex or heavy duty . They also do a three bar sports bar set up which i might change to for ordinary use like carrying my kayak and keep the full width bars for expeditions . 2008 MY Supercharged
14th Apr 2015 2:36pm |
RRAustria Member Since: 07 Apr 2015 Location: Graz Posts: 32 |
Hi Klemens,
21st Apr 2015 1:09pm |
Custom10 Member Since: 24 Jul 2014 Location: Asker Posts: 12 |
21st Apr 2015 9:45pm |
Nice setup!
22nd Apr 2015 6:40am |
yes 160 will have overhang on both sides and its also very long.
22nd Apr 2015 9:26am |
