Home > Wheels & Tyres > Tyre pressure
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Tyre pressure
Just fitted my new tyres, general grabbers AT, size 275/45/20
Anyone know the recommended pressure??
Thanks in advance 2014 vogue se
Post #322327 12th Apr 2015 2:43pm
as its not a standard size ,there isnt a recommended pressure.....i would use the 255 50 20 pressures.. ... - .- -.
Post #322330 12th Apr 2015 2:48pm
chefkenmore
Thanks stan Thumbs Up 2014 vogue se
Post #322331 12th Apr 2015 2:49pm
or for more comfort, drop by 2-3 psi.
My experience with general Grabbers is that they "harden" and loose a bit of grip on road surfaces (especially when wet!) over time (2 + years or so) but they last a long time.
Keep an eye on tread wear, if uneven in anyway there will be work to do on suspension bushes! .
Post #322339 12th Apr 2015 3:13pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
As you are fitting ATs rather than more asphalt tread, I think it should depend on what kind of roadways you are using. letters not necessarily in the right order
Post #322352 12th Apr 2015 5:08pm
