![]() | Home > Maintenance & Mods (L322) > Battery drain in amps (update) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
i'm sure i've seen some posts re this somewhere on the forum....have you done a search? ... - .- -.
kay Member Since: 13 May 2010 Location: Kent Posts: 16 ![]() |
Yes I did a search but no result on what it should be
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
i would be interested in answer to this aswell, mine only draws between 40 and 50 milliamps fluctuating but it too drains the battery and only just starts after 5 days. my local says it should draw less than 30 milliamp but a quick search on the net and i came across a few people saying a sleeping bcm draws 40 milliamps, confused. i went through all the fuses one by one and none of them made any difference to the power drain in a positive way, i even disconnected the satnav and it still draws the same power. |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
hello. I can only speak from personal experience having had these issues as well. There may be other solutions but what worked for me was simple and inexpensive. Buy a good battery and have a "battery tender" (not a recharger, a tender) PROPERLY installed. When you know the car will be sitting for a few days, simply plug it in. Fully healthy battery = happy RR, IMHO. |
i found this whilst searching , close to problem you have.. http://www.fullfatrr.com/forum/topic466.ht...tery+drain or.. http://www.rangerovers.net/forum/viewtopic.php?f=2&t=19826 ... - .- -. Y. O. L. O. . |
I don't know if there is an 'exact' figure for at-rest draw on the battery in the FFRR - it would vary dependent on equipment levels. I've never seen one.
The figures quoted for the battery are when it's new. A 3 year old 110aH battery is going to be more like half that in reality.
The drives door central locking doesn't seem to work at the moment like its stiff would this be the cause of the battery flattening
Unlikely. Even if it were to draw large currents due to being stiff, it would not operate for long enough to flatten the battery.
Fitted a new battery 110ah bosch the battary is still loosing charge just lasting longer, so there is a drain somwhere. Now its frosty at night the screen is frosty but the O/S is clear over where the dials & steering wheel is does this show where the fault is
If you're saying there is a part of the windscreen which looks like the heated screen elements have been on ------ they probably have been on (unless you have nice kind Pixies defrosting your screen) and they have mahoosive current draw. Much more than the heated rear window as there's a lot more element wires.
if its the heated front screen thats on all the time then logically the whole screen would be defrosted..i suspect something around or in the speedo part of the dash is generating just enough heat to clear the part of the screen, i cant think what it could be . ... - .- -.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 777 ![]() ![]() ![]() |
Logic has nothing to do with it! ![]() IIRC, the screen has a left and right circuit (perhaps a middle one too). When the screen on my D3 failed it was clearing one side but not the other. The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
That would be 6/100ths of an amp - or 60/1000ths which = 60mA. This alone will not be causing the problem on a new 110aH battery. I wouldn't think its your windshield heater - your battery would be dead after a night (is the section of defrosted windshield really clear top to bottom with sharply defined lines to the R and L? The screen has a L&R circuit - in theory it could be a stuck relay on one side. But even 1/2 of the windshield heater draws too much current for a week.) As I said, when you connect an ammeter to the vehicle you are only seeing a snapshot of what happens. In the worst case, you'll need a logging ammeter connected to the car for a longer period. RF interference is a possibility - even on the MKIII (it's common on the P38). Does this happen everywhere you leave the car parked (or do you always leave it in the same spot)? ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
