Home > Maintenance & Mods (L322) > Brake discs |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35416 |
defo get genuine from dan @ duckworths..
7th Apr 2015 12:03pm |
Lanby Member Since: 16 Jan 2013 Location: Leeds Posts: 11 |
Never thought about BBQ paint, cheers |
7th Apr 2015 12:56pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Am sure you cannot go wrong with genuine but I think this is one of those occasions where you really do have a choice,there are plenty of discs out there with far better performance than genuine and lots of good makes that are well trusted, well made and are up to the task that may be a little cheaper than genuine,just don't buy cheap !! |
7th Apr 2015 5:37pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
I ordered genuine from Dan at Duckworths and then painted hub and vents with high temp aerosol paint off ebay nearly two years ago. It has really stood the test of time, including a very high temperature trauma with a sticking caliper.
7th Apr 2015 6:36pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
I always paint mine in Engine Enamel spray paint and its brilliant long term sir |
7th Apr 2015 8:54pm |
tafftoo Member Since: 29 Jan 2015 Location: Staffordshire Posts: 40 |
I've just ordered a set of Brembo Pads and Discs from Advanced Factors. Decent price too |
9th Apr 2015 1:49pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I wouldnt contemplate anything but genuine. |
9th Apr 2015 2:09pm |
I'm assuming you have to have Brembo callipers to fit Brembo discs/pads? |
9th Apr 2015 2:31pm |
I would think so, but mine does have the brembo calipers so it makes sense for me |
9th Apr 2015 3:09pm |
Right, I've decided - Genuine parts from Dan at Duckworths, paint them with HT paint (probably ebay grey).
9th Apr 2015 3:28pm |
If you're talking about the torx screw that holds the disc on, I believe it's 35nm. |
9th Apr 2015 5:07pm |
A quick look online and you can find great quality discs from Ebc,mintex,Bosch,Britpart,Quinten hazel,Brembo all at prices similar if not better than genuine and some are painted that will last the lifetime so no need to paint,if you want to spend a few extra quid you will get much better slotted/drilled .Or you could be safe and choose Genuine! |
9th Apr 2015 7:34pm |
tafftoo, I was being a spaz, I meant the wheel bolt torque figures! |
9th Apr 2015 11:31pm |
140nm, 103lbft for wheel nuts.. ... - .- -.
10th Apr 2015 7:23am |
