Home > Technical (L322) > confused, eas issue |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Not sure where to jump with this but will ask for some advice fellas and apologies for another eas thread, I have searched the net and here on FFrr for some inspiration but one day think its compressor, the next think its valve block, then another its all working fine and dandy so cant be either.
7th Apr 2015 9:20am |
hmm, I know what you mean, new battery fitted November 2013 Craig, surely cant be that.....can it? will give it a charge thinking about it, not done for a while.
7th Apr 2015 9:38am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I'm with Craig, if it's showing the fault in the LCM then I bet it's down to low volts being interpreted by the LCM as a fault.
7th Apr 2015 4:45pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
May be the battery/charging circuit, but more likely you need to change your compressor .
7th Apr 2015 10:38pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
@Joe90, better both parts.... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
8th Apr 2015 12:11am |
8th Apr 2015 4:30pm |
While after a good charge and a recheck on alternator out put, iid shows between 13.2 - 13.8volts and my volt meter at the battery 13.8/9 while ticking over with no load, not so clever if it's ment to be at between 14.2 and 14.6
9th Apr 2015 2:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
mine is always at 14volts exactly and i've had no problems starting or with the suspension, so your voltage aint that far of mine. ... - .- -.
9th Apr 2015 2:22pm |
Hate to say it but that's what mine read for a few weeks before it packed up.... spurious faults kept popping up, then one day I smelt that lovely electrical burning smell and the ign light came on, battery power got me 10miles home, fitted Bosch recon alternator and it now sits at 14.2 most of the time... It does vary thought as it's a variable output alternator but never got to 14v (I've got a permanent voltmeter inside) when it was failing...
9th Apr 2015 4:10pm |
dunno pete, maybe....it all works and starts ok so 'if it aint broken' .......................[famous last words ] ... - .- -.
9th Apr 2015 6:04pm |
fingers crossed I say....but if it an't broke and all that....
9th Apr 2015 9:52pm |
