![]() | Home > Maintenance & Mods (L322) > A few issues |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
I have a couple of issues which i need to get the stealer to fix?
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2042 ![]() ![]() |
If not under warrenty find a good indie for LR related issues.
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
For the sensor, walk past them while its in parking mode. The one that ain't clicking is the duff one. |
It's not the heat shield as vie had a prod around and if I push on the front exhaust box the rattle goes - it's as if it's hitting the under body work.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
see this post ref you PDC sensor issue
hi, with the air con, kwik fit were doing the recharge for around £50 and if they cant get it 10% better then it was they dont charge you for it...check to see if the air con pump clutch is engauging V8 facelift Range Rover Autobiography 22" wheels.
How do you check if the air con pump clutch is engaging? CURRENT : FFRR 2012 4.4 TDV8
Revs will change, just.
if you look at it when the engine is running the head is still then get some one to switch on the air con and it will click and start spinning.
