Home > Maintenance & Mods (L322) > Shutting down at low revs with 473 & 483 FAULTS + IID TO |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
Can't remember if it was the exact same faults but I had two that were similar and it kept cutting out when near tickover, turned out to be the plug on the throttle body, it's right at the top front of the engine just under the cover you have off at the moment, pulled it out (has a detent to push in top and bottom) and gave it and the socket a good clean with some electrical cleaner and everything was OK again...
5th Apr 2015 8:13pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Thank you, I will try in the morning,
5th Apr 2015 8:22pm |
Cleaned everything : body throttle plus, airflow meter, check air filter and its housing, etc.
6th Apr 2015 2:23pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
Yes I had low idling and stalling after changing my torque converter.
6th Apr 2015 4:25pm |
Thanks, hopefully it is just this!
6th Apr 2015 4:39pm |
Glad that sorted it, I've had to do it twice in the last year, once when I think it got knocked and as Weejock says the pins are ridiculously small and only has to move mm's to cause problems, other time was when it got a bit wet... the moisture just stays in the plug....
6th Apr 2015 5:28pm |
