Home > Duckworth Parts > L322 Drivers Door lock assy O/S R/H/D Front |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Lock or latch? |
4th Apr 2015 9:49am |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
latch LR013378 £102.00inc vat
4th Apr 2015 9:58am |
Thats a very good price for a latch Dan... I remember what they used to cost on a D2's back in the day!!! |
4th Apr 2015 10:00am |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 |
Ahhh that's a problem then, I will have to look at the manual then, I thought that it was like the P38 three screws and the whole thing in one obviously not then. My drivers door locks with the key and button on the sill it does not lock or unlock with the remote makes a noise in the door but nothing happens. If everything is under control you are not going fast enough.
4th Apr 2015 11:46am |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
I'm in same position fella!
4th Apr 2015 3:31pm |
I changed the door latch today, that must be the easiest door latch I have ever changed on any car, makes the P38 one look ridiculously hard riveted to bars and struts in the door. None of that for the L322 door card off unplug the lock undo the bolts falls straight out the bottom. Easy peassy, new lock fitted and synchronised to the car. Fitted the new screen sensor but that does not work. If everything is under control you are not going fast enough.
10th May 2015 5:27pm |
