![]() | Home > Maintenance & Mods (L322) > Planning first transmission oil change |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
My '08 TDV8 Vogue has done 95k miles in total, of which I've done 29k in the two years I've owned it. It's still on its original gearbox (as far as I can tell from the service history which, although up-to-date, is not very detailed). After reading all the posts on here I think it's high time it had a transmission oil change but as a layman there are a couple of things I'm not clear on:
Hi Frank,
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1803 ![]() ![]() |
LR Interval is 150k, and is a simple drain/refill, using 4.5 litres
Thanks for the feedback, guys. Can you get the software update done without the oil change? Can ZF do the update or will the LR dealer have to do it? sodalis, you were right about the ZF centre in Frankfurt. I'll ring them for a quote. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Would personally get zf to do it if at all possible, after all they built it and will know it inside out |
OK, well it's taken a while for me to get around to contacting my local ZF centre but I have an appointment for the service in three week's time.
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
I understand it was the early models that had the filter as part of the pan.Mine is a 2004 and had the filter separate to the pan on 2 screws so I would guess yours will be the same you will just need the filter that is about £26 genuine.Mine also took 6.5 litres but I gave it overnight to drain so I got possibly a fraction more out than a quick drain.Have got to do my second drain yet but my mate who is a skilled lr technician insists I do it 3 times,i did buy a 20 litre tub so I may as well use it,it was as cheap as buying 15 anyway at £7/litre. |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
Hi
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Switching to the metal pan on the Disco makes sense, but not on the L322. I would stick with the combined plastic sump/filter.
Any particular reason why? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
There's no cross-member in the way (i.e. no need to disconnect the engine mount and jack up the engine) and the steel pan & separate filter are more expensive.
After watching this video of it being done on the Disco I see what you mean. A commenter said the metal pan is low profile. Is that why it's better for the Disco? Is it easier to access under the cross-member than the plastic one?[/url] 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
I changed my pan to a metal one anyway because if and when I do another oil change it is much cheeper to buy the filter than whole pan . The 6HP26 box is used in a lot of Ford products here and most installation have proved to be problematic due to poor oil cooling , as a result oil is changed on average much more frequently than 100.000 miles .
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
The metal pan has a separate filter so on a D3 for instance with a plastic pan, you need to jack up the engine to allow access for the pickup pipe (which is part of the sump on a plastic OE arrangement) on a metal pan, the filter is separate so after removing the metal sump, the oil filter (and long pickup pipe) has more room to drop out sir... Elevating the need to jack up the engine and all the necessary work that involves in that process ![]() The RR does not have the same gearbox crossmember (in the way) as the D3 so in terms of ease there is no need to replace the OE plastic arrangement with the metal one sir... Unless its your choice to do so as stated above ![]() Lastly, if you choose to change to the metal sump arrangement? Be warned, there are quite a few on the market without a drain plug ![]() ![]() ![]() Hope that all helps ![]() |
