Home > My Range Rover > London (UK) To Jammu (India): RR HSE 2003 Suspension Woes
cooldudesunny
United States 2003 Range Rover HSE Td6 Zambezi Silver
Ever since we left London we had the privilege of driving on butter smooth roads of Europe with one or two rough patches. Russia did not disappoint us either, with smooth multi-lane highways in the cities to single-lane clean roads through villages we were pretty happy with what we had treaded on till now.
We did read few horror stories of roads in Kazakhstan but we were very confident that RR would be able to eat it all and it was time to put that to test.
We finally (getting into Kazakhstan was quite dramatic) managed to cross Russia-Kazakhstan border. The moment we crossed the border, driving was more kind of a video game where you have to manoeuvre your car on an obstacle course. The road dint have potholes but dried out ponds!
RR was handling the so called road pretty well, we were feeling proud of the choice we had made when everyone that we know was calling us fools. Some idiotic thought in my mind asked me to raise the suspension so that i could drive RR on the side of the road and what a mistake that was!
Driving the car through whole of Europe, Turkey and Russia had worn out the suspension (not to forget that RR was a 2003 model with original suspension). The moment i pressed the control to raise the suspension, there was a hiss and full front part just dropped dead. I tried resetting the electronics and try raising it again but just a hiss and that’s all.
My initial guess was that maybe the pump failed as it is prone to failure and luckily i was carrying the repair kit (smart move eh). We got back into the car hoping to find a repair station nearby and started moving with a broken front suspension. We had a winch mounted in the front and it was not very high (the mechanic who did the setup was doing it for the first time and same applies to me as well), almost at the same level as the bumper. Now with the front down, the frame on which the winch was mounted started scraping against the uneven road, it added salt to RR’s wounds. We started moving very slowly looking out for any service station we could find. After covering quite a few miles, we found one workshop and got the winch frame cut out as the bolts that we holding it had deformed.
An important thing that we did not knew about Kazakhstan was that it does not have SUV’s … I know, it is sad and meant we would not be able to get the front suspension repaired. And only option we had was to cross whole of Kazakhstan with the front suspension down on those roads (i don’t know if can call them roads), and if that was not enough we had to do this in one day as we would not be able to enter Turkmenistan if we take more than a day!
We started driving RR at 80+ miles speed on tracks full of uneven tarmac with holes big enough to break any heavy duty suspension to pieces. RR took all in her stride and we were shockingly impressed. Even without the suspension, RR was not rattling our bones and appeared as if only the suspension was stiff. However it was good enough to get us tired, we found a room in some hotel in Kulsary and called it a day.
We woke up a little early, tried resetting the electronics to try our luck once again but no magic happened
Left with no choice we continued our journey, the road now was quite better with odd stretch of bad road till Beyneu.
The road from Beyneu towards the Uzbekistan border (90+ KMs) was non-existent, we had to relying heavily on the GPS we were using and and it just showed a straight line towards the border. The road was made of sand, mud, stones and since there were no road marking, we did wander off few times but thanks to helpful locals we were back on track.
We finally reached Uzbekistan border, it took a while for us to unload all the stuff, get them scanned, complete legal formalities. In 3-4 hours we were back on road, we checked with one taxi driver and he confirmed we would find a mechanic in Khiva, bad news was that for the first 100 KMs or so, roads were not that welcoming. So, plan was to reach Khiva and get the suspension fixed as Uzbekistan had SUV’s and workshops to fix them.
After driving whole night we reached Nukus, we tried finding a hotel to stretch out legs for few hours but surprisingly none of the hotels had a room to spare! With no choice left, we continued towards Khiva. Thankfully son of the hotel owner in Khiva was both well conversant in English and knew a good mechanic too. He took me to this guy, and the way he started the diagnosis, it made me confident that he would do something about it. Hotel owner’s son translated it to me that the mechanic had recently fixed another RR recently also with suspension issue.
Once his inspection was over, he told us there was a big hole in the left front suspension. He removed the suspension and started checking within his circle if it could be mended because finding a replacement had lesser chances then winning a lottery!
With the puncture expert giving up, only way out was to remove the rubber bladder and replace it with a coil. Luckily the mechanic had coil from a passenger vehicle lying around, unfortunately it was not strong enough so he combined two together and the final product kind of held the RR perfectly. He blocked the air inlet for the damaged side, i gave RR a reset, plugged the key in, switched it on and RR was back up with the front held high .. Woo Hoo Smile
At that instance thought of replacing the right suspension with a coil did occur to me but i dint want to fix what ain’t broken and moreover the mechanic did not have another pair of coils and we were running out of time to cross Uzbekistan and enter Turkmenistan.
Post #320398 29th Mar 2015 10:03pm
simply....amazing Bow down Bow down Bow down Thumbs Up .
Post #320400 29th Mar 2015 10:15pm
Wow, i wanna do it too Mr. Green Mr. Green Mr. Green Thumbs Up
Post #320404 30th Mar 2015 12:06am
cooldudesunny
Thank you for the kind word guys Smile Nothing is IMPOSSIBLE - The word itself says I M POSSIBLE.
Roadtrip - London 2 Jammu [Facebook] [Instagram] [Twitter] [Website]
Post #320414 30th Mar 2015 6:05am
wealy
Fantastic😀
Good luck guys
Post #320421 30th Mar 2015 6:56am
Great to see the spirit of adventure alive and well.... read loads of articles about people doing similar things and "having" to take a Toyota because nothing else would do it !!!! they spend months rebuilding it and take spares for everything and still break down.... good old Rangie.... soldiers on with a broken leg and takes it in it's stride...
Good luck to you chaps and keep us posted on how you get on....
If the other side pops and you can't find springs and if the split is at one end, and it usually is, then you could make the airbag shorter with a large jubilee clip, or several joined together....
Failing that you can get some height with a lump of wood wedged in the suspension to get it off the bump stops.... Pete
Post #320435 30th Mar 2015 8:07am
I felt very proud of my TD6 when reading this. Thumbs Up
Post #320448 30th Mar 2015 8:38am
J90
France 2006 Range Rover Vogue Td6 Java Black
Keep it up Sunny Thumbs Up just curious what tyres are you running on? Travelling around in circles again.
Post #320450 30th Mar 2015 8:48am
cooldudesunny
wealy wrote:
Fantastic😀
Good luck guys
Thanks wealy Smile
Thank Haylands, everyone was pushing Toyota to us as well! My wife had a slight back pain and only thing the doctor ordered was a RR Very Happy
Indeed, we had the same feeling after the end of the trip and we are so glad we did not listen to anyone and everyone. We did face issues (i will be covering more of them soon), but the was RR came out of it, it was actually impressive.
Thanks J90, they are Michelin Latitude Alpin LA2 235/65 R18 110H XL. Not even 1 puncture during the whole trip, i am now a Michelin fan for life Smile Nothing is IMPOSSIBLE - The word itself says I M POSSIBLE.
Post #320540 30th Mar 2015 4:15pm
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Unbelievable. What an adventure. I think all would agree that really is one for the Bucket List.
Would love to do something like that Thumbs Up Thumbs Up Thumbs Up Porsche 993 Targa, Buick Skylark Convertable 1968
Post #320550 30th Mar 2015 4:53pm
ebajema
Brilliant trip and big compliments for doing it in the best vehicle for such a trip, a FFRR.
A trip like that is on my to do list as well, after "the Long Way Down in a FFRR" of course Smile Smile Smile
You do know that suspension struts can be bought from Island 4x4 and they courier them anywhere in days. I had mine for the 4.2 delivered in Nigeria in under a week Smile. Granted, it was in Lagos Smile. MY 2010 5.0 SC Galway green and sand interior!!
Post #320631 31st Mar 2015 11:44am
duckworthparts
Site Sponsor
Thumbs Up Bow down You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #320636 31st Mar 2015 12:02pm
n1cktdv8
Great adventure...keep the diary entries coming....or we'll start bickering about suspension faults Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #320639 31st Mar 2015 12:10pm
ebajema
I agree, more on the trip less on the faults (we have enough of that on the forum) and plenty piccies please Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #320642 31st Mar 2015 12:19pm
cooldudesunny
Thanks Chillb. It definitely was one of the most amazing things we have every done, and would love to do something similar again Smile
Thanks ebajema. FFRR is indeed the best out there, we bought another one once we came back to Chicago. We did not have more than a day to get it fixed otherwise would have ordered.
duckworthparts wrote:
Thumbs Up Bow down
Thanks duckworthparts Smile
Thanks n1cktdv8. Blog is there already but i will be creating a thread in the forum as well.
ebajema wrote:
I agree, more on the trip less on the faults (we have enough of that on the forum) and plenty piccies please :Wink:
Surething Smile Nothing is IMPOSSIBLE - The word itself says I M POSSIBLE.
Post #321157 3rd Apr 2015 8:59pm
