Home > Technical (L322) > Steering angle plausibity
Bingy
England 2010 Range Rover Vogue TDV8 Bonatti Grey
Hi all, 54 plate 4.4
only had the FF 3 weeks, Love the motor but this is getting to annoy me.
First off, normal driving around town everything is fine. No lights, bongs etc
Onto the motorway fine, upto 60, motor drops as it should.
Increasing speed, 70 ish for a few minutes then bong
ABS inactive, HDC inactive Suspension inactive error message and motor returns to normal height.
The car is still drivable
After pulling over and turning the ignition off for a few minutes then back on,
everything is back to normal, no bongs, error messages
motor drives as normal once again, drops to lower cruising height for a few minutes again and then all re-appears.
Since i already had the hawkeye i pugged this in and came up with the error
'Steering Angle Unplausable'
Looking on the internet, trying to narrow the error down i decided to invest in the IId Tool.
After going through all the setup and updating the tool, i read the fault code which came up with the same answer within the ABS ecu
1/1 29 steering Angle Plausability.
I was hoping that the tool would be a little more specific in identifying the sensors, or do i indeed need a new steering wheel sensor?
Any help would be great thanks
John
Post #320384 29th Mar 2015 9:13pm
Have you emailed GAP?
Post #320389 29th Mar 2015 9:31pm
Sounds like you need a 4 wheel alignment
Post #320392 29th Mar 2015 9:36pm
Bingy
i Didnt no. This is the first time i have used the tool
So if i emailled them with the fault they maybe able to come up with a more specific answer
I didnt even think to consider emailling them.
I will get onto it straight away
Thanks
Post #320393 29th Mar 2015 9:40pm
Patrick is really good Thumbs Up
Post #320395 29th Mar 2015 9:47pm
Bingy
I thought that as well
after ring round garages for the Hunter wheel alignment, the nearest was a kwick-fit garage.
After booking it in for last satuarday morning
I arrived, he asked me what car it was for and after i showed him the FF
he made an excuse that the electics had gone faulty and had been sent back to bosch.
Needless to say, thankfully it never happened
Post #320396 29th Mar 2015 9:48pm
I had that in the disco (or something similar) the Censored head at the garage had hit the calibrate steering angle sensor button on his diagnostics with the wheels pointing in the wrong direction!
Was sorted by recalibrating. The car thinks it should be going round a corner but all the other sensors tell it that it isn't, so it throws a wobbly.
Steerng angle reset should hopefully sort it There is nothing that can't be fixed with a hammer😜😜
Post #320399 29th Mar 2015 10:14pm
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
I would agree, had the same thing in my Discovery. Fitted new tyres and fella recommended a 4 wheel alignment, 5-6 months later same symptoms. Turned out they had incorrectly aligned the car and over the months it kept compensating until it had reached its limits. Had a full alignment done (reputable indy) and the steering angle reset. No more 'bonging' and hitting the floor. Porsche 993 Targa, Buick Skylark Convertable 1968
Post #320553 30th Mar 2015 5:12pm
I had the exact symptoms the op had, bongs, suspension dropped to the floor and lots of error messages.
All I wanted them to do was enable the fbh remote module!!!! There is nothing that can't be fixed with a hammer😜😜
Post #320579 30th Mar 2015 7:47pm
Bingy
thanks for all the help and sorry for the delay as i am away during the week with work commitments and limited internet.
Received an email back from Patrick with this response
1/1 29 steering wheel plausability.
This fault would be related to the steering wheel angle sensor. These are prone to fail on these vehicle. When they do, the ABS/HDC ECU is not happy and will light up the warning lamp on the instrument pack. If it is not turned ON, I would simply clear the fault and not bother about it.
Best Regards
Patrick Meilleur,
Bachelor of Engineering
GAP Diagnostic
So now the dilemma is do i get the sensor replaced then do the 4 wheel alignment
or
do i just go for the 4 wheel alignment hoping that this cures the fault
thanks again
Post #320983 2nd Apr 2015 3:06pm
Googsy
You could try ensuring wheels are dead straight ahead and then go through the steering angle reset process with the IID tool. That may fix the issue. It sounds as mentioned that the last alignment done the wheels were not straight ahead when sensor was reset. I can't see it doing any harm given the current situation. I would then have car alignment done to make sure all is nice and straight Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #321042 2nd Apr 2015 8:36pm
Bingy
Update..
after going around a few 4 wheel alignment places equipped with the Hunter machinery,
these machines seemed to have the SAS grayed out on all Land rover models.
Getting desperate, i went round to my local indie, who advertises 4 wheel alignment.
After chatting with a mechanic, he duly pointed at the local ATS garage down the street.
'We send all the motors there.'
So 40 minutes later, the job was finished.
Apparently the tracking was was out.
I could see alterations being made via a computer screen in the waiting room
I went for a test drive and normal service has been resumed.
Thanks for all the advise Thumbs Up
Post #322214 11th Apr 2015 7:15pm
