![]() | Home > General > My part their labour - reasonable? |
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 ![]() ![]() |
If this fault was present when you brought the car then it's not warrenty that entitles you to a fix, it's your statutory consumer rights that mean they need to pay for it all. |
Remind them of that if they push back, pay then small claims... |
Thanks for the replies Jim and for the responses to the poll.
So, rang for an update today as to how the repair was progressing. Was told the part on back order had been ordered and would arrive next week and they'd get on with the repair then. But I sourced and had the part delivered to you 3 days ago? |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
As I keep saying keep away from main dealers unless you want stupid or to be ripped off, you may as well set fire to cash or give it away, too many years in industry to know the majority are high end crooks with big overheads, _____________________________________________________
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Why wouldn't the OFH be a warranty repair? Can't check my warranty doc (as it's in glovebox n FF is in for warranty work, has an oil leak |
Scotty, they took the engine out to repair a ladder frame leak under warranty. Into the 2 to £3k based on MD labour rates.
Yup they can sort it too right but after I bet you won't use them, seen more cock ups from md's than Indy over the years they think they can get away with it as there big and shinny! Wrong make sure you don't give in to these barstewards good luck |
