Home > Maintenance & Mods (L322) > Slight knock developing on front end? |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
Hi Folks.
23rd Mar 2015 9:39am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Not enough air in the front tyres??? |
23rd Mar 2015 9:44am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Recently changed all mine, track rod ball joints where shot, and the 4 lower ball joints and arms, all parts sorced from Dan at Duckworth LR If it dont work.......burn it!
23rd Mar 2015 9:47am |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 |
mine started knocking from the front nearside, turned out to be a very slightly worn track rod end, replaced it and the knock went away. |
23rd Mar 2015 9:52am |
Thanks folks..
23rd Mar 2015 9:59am |
A little sir |
23rd Mar 2015 10:02am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
I had a lower track control arm replaced for a similar noise but in reality it could be any part of the front suspension. Got - 2017 SDV8 Autobiography in Loire Blue
23rd Mar 2015 10:20am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Check the Anti-Roll Bar Drop Links, they're a common reason for the knocking.
23rd Mar 2015 12:22pm |
Thanks. I will have a look at droplinks.
23rd Mar 2015 8:23pm |
MOT man passed the car with an advice on the o/s Bottom ball joint.
24th Mar 2015 5:25pm |
Happy days
24th Mar 2015 5:50pm |
Thanks for your advice once again
25th Mar 2015 5:25am |
25th Mar 2015 7:03am |
