Home > Maintenance & Mods (L322) > Rear light condensation - My fix.
Fed up with this happening regularly, I decided to do something about it this morning.
I never liked the idea of drilling holes in the front as I think water and dirt would get in too easily.
So I decided to take the lights out, it's so quick and easy, 2 screws and pull, and drill a hole underneath. I think it will be less susceptible to water and dirt getting in. The hole is at the bottom underneath the side reflector. It's a 2mm hole.
Post #176739 9th Mar 2013 11:05am
ebajema
If it is still relatively accessible (the hole) then you could get/make a small silicone or rubber plug. Stick it in and when you have condensation issues, pull it out for a day or night and then back in again. That way lot less risk of water and dirt getting in Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #176741 9th Mar 2013 11:16am
The above is the solution I adopted about a year ago albeit with 3mm holes.
Been very successful to date, no re-occurence of the dreaded condensation. Thumbs Up
Post #176746 9th Mar 2013 11:34am
Thumbs Up Good stuff. I thought I would go 2mm first and if they blocked up or did not offer enough ventilation then I would go to 3mm. Previously..
Post #176749 9th Mar 2013 12:05pm
pami
United Kingdom 2008 Range Rover Vogue SE TDV8 Bournville
please forgive my ignorance as ive not played with a rear light yet (still need to buy a RR!) but isnt there enough room in there to leave a silicon pouch thingy (like you get shoes/laptops) in there somewhere?
I had the issue on a Passat headlight a long time ago and that sorted it out for me...
Unless im being stupid (quite a possibility too!)
Post #176757 9th Mar 2013 1:06pm
^ Whistle Laughing
Pami.. It's a sealed unit. The seal goes eventually and lets moisture in. I have read of people running araldite around the seals again but I hope the hidden hole will do the job. Thumbs Up Previously..
Post #176767 9th Mar 2013 1:55pm
Don't know about a 2006 light but the earlier ones are provided with ventilation and still condensation forms. They are not sealed units.
The drain holes drilled in the bottom simply allow any rain water that has leaked in by way of the inadequate perimeter joint to drain away and also provide a nominal improvement in ventilation.
Although the body of the units are ventilated, the effect of this is minimised by virtue the large void behind the clear outer side/rear is only connected to the ventilated space by a small perimeter gap round each of the red/amber lenses.
Resealing of the perimeter joint with Araldite will certainly have the effect of reducing condensation but will not reduce it completely.
Even new units, perfect in every way, will still suffer nominal condensation due to the ever changing atmospheric conditions they are subject to. In this case however the ventilation provided undoubtably helps to keep the units clear due to temperature changes and external air moisture content.
Plastic light fittings on cars have always suffered condensation but previously light fittings tended to be constructed from thick red or amber plastic which tended to hide the condensation.
Modern "clear" light fittings have added to the problem as you can now see the condensation.
Post #176769 9th Mar 2013 2:21pm
I agree, I have just had a brand new front NS lamp cluster fitted, it still fogs up at the bottom and that is straight out of the box. There is nothing that can't be fixed with a hammer😜😜
Post #176833 10th Mar 2013 10:34am
klf400
The 2010 rear lights can condensate as well , what a pain Crying or Very sad 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #176931 10th Mar 2013 9:10pm
ebajema
The headlights have breather tubes on them, I assume to allow for the expansion of the air due to the heat of the bulbs. That of course draws moist air in when the headlight cools. Taillights should have virtually no heat at all due to the LED lights but still sunlight will warm up the insides quite a lot, raising the air pressure. I guess that even time, that "fatigue" of the plastic, plus UV radiation (degrades almost all plastics) will form cracks in the plastic and or joints, causing air to be able to go in and out. MY 2010 5.0 SC Galway green and sand interior!!
Post #176946 11th Mar 2013 7:18am
Semperfidlas
England 2005 Range Rover HSE Td6 Zambezi Silver
This has been a constant problem on these vehicles and is well known to Land Rover Ive authorised lots of these to be changed under warranty without any come backs, even been able to get vehicles out of warranty done provided therer was no damage and they haven't been tampered with.
Post #247714 12th Mar 2014 10:02am
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Can the light units be opened up at all - can drill the hole but can see staining where condensation has puddled inside. 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #319130 22nd Mar 2015 10:47pm
No sir... The 09> headlights are sealed with an un-meltable glue & the rears are sonic welded together so NO they won't come apart with ease... Rolling Eyes
Post #319136 22nd Mar 2015 11:23pm
Triarii
Doh! Censored I suppose I should have guessed that it was easy and logical then LR wouldn't entertain the idea..... 17 MY Corris Grey 4.4 VAB
Post #319275 23rd Mar 2015 6:41pm
Googsy
Rumour has it they can only be opened in the Cotswolds some sort of mystic magic Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #319307 23rd Mar 2015 9:20pm
