Home > In Car Electronics (L322) > Getting a wire into engine bay
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Is there an easy way to get a wire from the dash into the engine bay?
Post #318958 21st Mar 2015 2:44pm
on the inside,drivers side, remove the tread plate and then the plastic that houses the bonnet release ..
looking at the engine bay , at the top left is a section where the wiper mechanism is ..look down and theres a thick bunch of wiring going into the inside of the FF..
with a screwdriver make a hole in the rubber to one side of the thick bunch of wires ..this is your entry into the inside.. ... - .- -.
Post #318967 21st Mar 2015 4:17pm
There is another similar route on the other side where you can drop a wire down to the main fuseboard, but you would need to remove the battery to get at it properly. .
Post #318985 21st Mar 2015 7:28pm
Lad
Cheers for your replies. I will have a nosey tomorrow. Thinking of extending my laser detector sensor pickup down to the bumper area. Although thinking of upgrading completely to a new system that involves wires thru to that area anyway. Thumbs Up
Post #319018 21st Mar 2015 11:03pm
